It is currently Tue Oct 13, 2026 7:45 pm
 Post subject: bmw wheels?
PostPosted: Mon May 19, 2003 1:39 pm
Does the bmw wheels with 5*120mm fit on the f-body...I figure since that's just .6mm off the f-body bolt pattern....lets say a 18*8.5 with 35mm in offset?
with aprr 2.3 cm of bead flange thickness(flanges on the outer edge of the wheels that hold the tire beads on the rim)
I get for stock 16*8:
Offset = 55mm,2.165"
Backspace = 6.615"
Frontspace = 2.28"
BMW 18*8.5:
Offset = 35mm,1.378"
Backspace = 6.08"
frontspace = 3.32"
So they will stick out appr 3.32-2.28=1.04" 26.4 mm further out....
I think I've seen som wheels somewhere for the f-body with 3.8" frontspace...so it should work fine right?
Opinions?
Thnx.
-95 Z28 M6, Hooker SC shorties, 3" Catback, B&M Ripper shifter, LT4 Km, !Cags, Home made CAI with KN, Fan switch, Headlight covers.
PostPosted: Mon May 19, 2003 2:51 pm
Yes, they will fit fine. Numerous fbody owners have gone this route, seeing as how there are so many more wheels available for the bimmer. ;)
