Page 1 of 1
[ 9 posts ] |
darookie
Post subject: Pin-stripe removal? Posted: Thu Mar 07, 2002 8:33 pm |
Joined: Sun May 27, 2001 9:46 pm Posts: 486 Location: Ft. Lauderdale, FL
Anybody have a suggestion? Alcohol, etc.??? Thanks. Trying to help someone out. Mike
guerardsgt
Post subject: Posted: Thu Mar 07, 2002 8:56 pm |
Remember when I stripped all the wax off my car and then buffed it. That's pretty much your only bet on getting rid of the stickey marks. I wouldn't recommend using Rubbing Alchol you may rub the paint off the car. If rubbing alchol can remove super glue imgine what damage it can do to paint. The way I stripped my car and removed some small scratches out of yours is your best bet. I would recommend being very careful on how long you hold the buffer in one place with that abrassive compound. Let me know and I'll give you further instructions in an e-mail.
Post subject: Posted: Thu Mar 07, 2002 10:40 pm |
fbody97
Post subject: Posted: Thu Mar 07, 2002 11:07 pm |
Joined: Mon May 28, 2001 7:29 pm Posts: 1175 Location: fairfield, CA
gasoline will work. should be alright as long as you wash the spot after. Gas has spilled out of the gas tank on my car several times.
_________________ Dave Brooks
Jr
Post subject: Posted: Fri Mar 08, 2002 6:51 am |
I like GOO-GONE I have used it on small spots of my car and it has never done anything to my paint or finish.... it's just citric acid.
My96z
Post subject: Posted: Fri Mar 08, 2002 7:42 am |
Just pull em' off! They will peel all the way off. The use alchohol to get the stickum off.
Hawk
Post subject: Posted: Fri Mar 08, 2002 8:43 am |
careful guys Gas alchohol nail polish remover will screw your clearcoat up. That would suck!!!
SRZ
Post subject: Posted: Fri Mar 08, 2002 9:05 am |
Power blow dryer and some type of citric compound that's non abbrasive. Any auto store carries the stuff just can't remember the name.
RT1
Post subject: Posted: Sat Mar 09, 2002 1:32 pm |
Joined: Mon May 28, 2001 7:46 pm Posts: 1091 Location: El Paso, TX
I was thinking of doing the same thing with my pin stripes... I was worried about the paint being a differant color under the stripes. I had this car in FL for a long time, then El Paso, so I hope it didn't fade.
RT1
Page 1 of 1
[ 9 posts ] |
Users browsing this forum: No registered users and 9 guests |
