It is currently Tue Aug 25, 2026 3:10 am
 Post subject: Paging Garry
PostPosted: Wed Jan 01, 2003 5:14 pm
Garry, I have a question about your car. Right in front of the shifter, there is a small rectangular panel where the top switch is located. On your car, is the top switch the only switch in that panel or are there two switches? If there are two, what is the other switch? Also, does it look like the top switch? I am just curious. Thanks.
Jerry
 Post subject: Re: Paging Garry
PostPosted: Wed Jan 01, 2003 9:02 pm
Euro-Camaros have the headlight hight adjustment there, too ... small rotary dialer ... if you need to, I can take a picture ...
PostPosted: Wed Jan 01, 2003 10:48 pm
No, don't need a picture. I was told that there was a fog light switch there that looked like the switch for the top. Guess I will have to research some more. I want to put a power antenna in and want a switch so I can lower the antenna when I am listening to CDs. Hate the whistle from the antenna when I am cruising on the autobahn.
PostPosted: Wed Jan 01, 2003 10:57 pm
No, fog lights (rear and front) are switches in the center top console, over the radio, where the "Camaro" logo is ...
PostPosted: Thu Jan 02, 2003 6:08 pm
Euro Camaros:
Top row: 1. Fog front 2. ASR (Z28s only) 3. Fog rear 4. Convertible roof (V6s in Germany only)
Next to ashtray: Headlight adjustments :!:
Hope that helped!
BTW Jerry, sorry for letting you hang on your request, i was not able to work quite some weeks. Will explain on the next meet.
R@M
Got boost?
PostPosted: Thu Jan 02, 2003 6:36 pm
Rampage wrote:
Euro Camaros:
Nope, roof control is right next to the headlight control on mine ....
