It is currently Mon Aug 24, 2026 8:29 am
 Post subject: PAGING RANDY!!
PostPosted: Wed Jun 06, 2001 11:56 am
Hey man, is your T56 aftermarket? If so, I might have a ripper shifter for you. Let me know!!
PostPosted: Wed Jun 06, 2001 12:51 pm
Jack
Is there a difference between factory and aftermarket?
PostPosted: Wed Jun 06, 2001 1:26 pm
Well, the thing is, I won an auction on ebay for the ripper, and when I got it, it didn't fit. I called B&M, and they said that it was for an aftermarket Borg Warner transmission.
PostPosted: Wed Jun 06, 2001 1:34 pm
???????? other than bell housing, and some synchro differances I thought they were the same also. Maybe since Tremac bought out Borg-Warner specs have changed??
PostPosted: Wed Jun 06, 2001 2:15 pm
I'll put it this way, the part # is different, and the base of the one that I have to sell is just a wee bit smaller than my new one.. :confused:
PostPosted: Wed Jun 06, 2001 4:40 pm
No Jack, my T-56 is out of a 94 Z28. Maybe it will fit a LT1 T-56? I know the LT1 T-56 and LS1 T-56 have some differences. No clutch fork, different bellhousing, who knows??
PostPosted: Wed Jun 06, 2001 4:48 pm
who knows??
Not me, but I can let you borrow it, and if it works, you can have it, and if not, no skin off of anyone's back!!
 Post subject: how much
PostPosted: Thu Jun 07, 2001 5:25 pm
Hey if it doesn't work in randy's car how much do you want for it. If your not going to sell it don't worry about it.
PostPosted: Thu Jun 07, 2001 6:02 pm
Isn't the part # the same for '93-'01?? I'm pretty sure it is....
PostPosted: Thu Jun 07, 2001 7:21 pm
Hey they won't let you turn in back in for the correct one. Or give them the part # so you can find out what car it does go to.
PostPosted: Thu Jun 07, 2001 8:10 pm
All they told me was that it was for aftermarket transmissions. The part # is 45053
