It is currently Mon Aug 24, 2026 7:32 pm
 Post subject: Pin-stripe removal?
PostPosted: Thu Mar 07, 2002 8:33 pm
Anybody have a suggestion? Alcohol, etc.??? Thanks. Trying to help someone out. Mike
PostPosted: Thu Mar 07, 2002 8:56 pm
Remember when I stripped all the wax off my car and then buffed it. That's pretty much your only bet on getting rid of the stickey marks. I wouldn't recommend using Rubbing Alchol you may rub the paint off the car. If rubbing alchol can remove super glue imgine what damage it can do to paint. The way I stripped my car and removed some small scratches out of yours is your best bet. I would recommend being very careful on how long you hold the buffer in one place with that abrassive compound. Let me know and I'll give you further instructions in an e-mail.
PostPosted: Thu Mar 07, 2002 10:40 pm
Heat gun or heat lamp
PostPosted: Thu Mar 07, 2002 11:07 pm
gasoline will work. should be alright as long as you wash the spot after. Gas has spilled out of the gas tank on my car several times.
PostPosted: Fri Mar 08, 2002 6:51 am
I like GOO-GONE I have used it on small spots of my car and it has never done anything to my paint or finish.... it's just citric acid.
PostPosted: Fri Mar 08, 2002 7:42 am
Just pull em' off! They will peel all the way off. The use alchohol to get the stickum off.
PostPosted: Fri Mar 08, 2002 8:43 am
careful guys Gas alchohol nail polish remover will screw your clearcoat up. That would suck!!!
PostPosted: Fri Mar 08, 2002 9:05 am
Power blow dryer and some type of citric compound that's non abbrasive. Any auto store carries the stuff just can't remember the name.
PostPosted: Sat Mar 09, 2002 1:32 pm
 ICQ  YIM  Profile
I was thinking of doing the same thing with my pin stripes... I was worried about the paint being a differant color under the stripes. I had this car in FL for a long time, then El Paso, so I hope it didn't fade.
RT1
Users browsing this forum: Bing [Bot] and 3 guests
