It is currently Mon Aug 24, 2026 9:43 pm
 Post subject: Hello....
PostPosted: Sun Jun 30, 2002 4:33 pm
Just stumbled upon this sight so I thought I'd post a hello to you all from the Midwest-USA.
93 TA, Red, 4spd, w/WS6 upgrade- hood,intake,badging & 17x9 WS6 rims, K&N, 52mm tb, Ed Wright programming, 3.73:1 gearing, Edelbrock LCA's, LG Adj pnhrd rod, BMR K-Member, PST F&R sway bars, PST polygraphite front bushing kit, Energy Suspension Trans Mount, TPIS Alum 3 1/2" Drv Shft, Alston STB, PF-Z pads F&R, Muflex 3 1/2" custom exhaust w/ HI-Flo cat & muffler, 160 deg t-stat, MSD 6AL w/MSD coil,Accel 9000 plug wires, LPE DD subframes, adj fuel press reg, Crane Cams Gold Racing Series 1.6 RR's, CC305 cam, TPIS/AFR Level III heads, 2800stall.
PostPosted: Mon Jul 01, 2002 6:30 am
Are you coming to Germany to run on the bahn.
PostPosted: Mon Jul 01, 2002 12:12 pm
Where-a-bouts in the Mid west... I'm from Wisconsin
PostPosted: Mon Jul 01, 2002 1:15 pm
Eventually I'd like to frieght the the car over there and stretch it's legs out, but that's pretty unlikely. So, I take it to Road America and beat on it there.
Jr- I'm in Milwaukee, where are you from in WI?
PostPosted: Mon Jul 01, 2002 1:45 pm
I'm from Kenosha!!! Small world..... I'll be back there in about 3 weeks for some leave inbetween stations....... to bad I won't have the car though....
PostPosted: Mon Jul 01, 2002 11:23 pm
Small world indeed! I and a few others from the Midwest F-Body Assoc will be in the Racine parade on Thurs with our rides. You should check out MFBA.ORG -if your not already registered on it. What's it like having the Z oversees?
PostPosted: Wed Jul 03, 2002 11:09 am
If your up and running it's an awsome feeling being able to push your car to the max whenever you want. If it brakes then it sucks because getting parts is some times a little bit of an effort. (If you want just join the military and request Baumholder Germany you'll keep the miles down while your here because you'll always be gone.) J/K sorta
PostPosted: Wed Jul 03, 2002 12:34 pm
Welcome to the board! Disregard all the bashing going on right now.:) Later, Mike
PostPosted: Wed Jul 03, 2002 1:28 pm
Mike do you want me to shrink that picture down for you. I did johns for him last week, let me know and i'll shrink it and post it in the pic post forum for you to retrieve.
