Page 1 of 1
[ 9 posts ] |
JackZ28
Post subject: Roy, Ford 8.8 VS. 9" Posted: Tue Oct 22, 2002 11:55 am |
I am hearing now that the 8.8 is probably better, or just as good as the 9". Is this true? If so, this would be a much cheaper route.
Post subject: Posted: Tue Oct 22, 2002 12:28 pm |
Post subject: Posted: Tue Oct 22, 2002 12:49 pm |
Joined: Fri Apr 12, 2002 12:46 am Posts: 196 Location: Lawton OK
Quote: I am hearing now that the 8.8 is probably better, or just as good as the 9". Is this true? If so, this would be a much cheaper route.
I doubt it dude. Sure, you cant swing a dead cat without hitting a 87-02 GT, but cheaper? Reason I think this, is not very scientific, but if it were cheaper/easier you'd see it or hear about it, instead of the 9" or 12" ones.
Strength wise if you already had a 8.8 (course you wouldnt have a Fbody then) there would be zero reason to upgrade. But if your gonna do it, I guess people assumed you would want to do it overkill so the 9" kits and 12bolts rose to the front
JackZ28
Post subject: Posted: Tue Oct 22, 2002 1:24 pm |
Hawk
Post subject: Posted: Tue Oct 22, 2002 7:15 pm |
How much cheaper? will you still have piece of mind I have done worry free 4800RPM launches with street ET's Do not think I will break that 9". If I ever get serious I could get another 3rd member set up with some 4.56 or something for a little nothing and change them out in a couple hrs. just my .02 cents
Post subject: Posted: Wed Oct 23, 2002 12:05 am |
The only problem I see with it right now, is the only ones that can do this are people that are in close with a fabricator. The suspension pickup points and axle width's among other things have to be included on it before people like you or I can buy them.
Now if a company like currie or strange were to step up and do it, I'm not sure it would be any cheaper than a 9". Would be cool if they could release something like this for about 1500 though!!!
Hawk, anything you can throw at it, that 8.8 will shrug off. It is a really stout piece. Only thing that is a negative, Roy eluded to. The C clips. If you run 10.99 or faster that axles have to be attached, ie no c clips
Hawk
Post subject: Posted: Wed Oct 23, 2002 5:49 am |
I have heard it is pretty strong. I went with the 9" because I could not afford to figure it out. Gotta be reliable and strong and a bolt in package nothing more frustrating than getting a wrong piece in the mail.
JackZ28
Post subject: Posted: Wed Oct 23, 2002 10:31 am |
Hawk
Post subject: Posted: Thu Oct 24, 2002 7:47 am |
You can get a 9" cheaper I did the upgrades axels case brakes with rotors and so on. you could get it for $2000.
Page 1 of 1
[ 9 posts ] |
Users browsing this forum: No registered users and 40 guests |
