It is currently Tue Aug 25, 2026 8:50 am
 Post subject: BITBURG meeting?
PostPosted: Tue May 06, 2003 8:29 pm
do any of you plan on meeting anywhere in k-town or rammstien? some of us mannheim peeps are making are way up thier (hopefully). It would do some of us good to follow those that know how to get thier with no problems.
word?
PostPosted: Tue May 06, 2003 8:56 pm
We are meeting on Ramstein, in the parking lot across from the AirNorth HQ. If you drive down the main road, you will see us shortly after you go under the overpass. :)
PostPosted: Tue May 06, 2003 9:06 pm
oposite side of base from the junkyard? the one with the huge parking lot!?
what time are yall meeting?
I saw alot of mixed posts about this.
thanks
PostPosted: Tue May 06, 2003 9:51 pm
No, you go in the main gate, and 150 meters after you go under the over pass (ON BASE), you will see a small parking lot. We will be there.
PostPosted: Tue May 06, 2003 10:52 pm
so it is the same side the J-yard is on!
I thought the main gate was the other side where the big parking lot was, because coming off of A6 north that is the only sign referencing Ramstein air base. I think I know what you are talkin about now!
but,
What time?????
PostPosted: Wed May 07, 2003 5:07 am
Yep same side where you run into the junk yard. See you then!
PostPosted: Wed May 07, 2003 6:57 am
Be there at 9. We will leave at 9:30! ;)
PostPosted: Thu May 08, 2003 7:59 am
Jack How quick do you plan to run?
