It is currently Tue Aug 25, 2026 7:51 am
 Post subject: f-body Software (error, digramm, etc.)
PostPosted: Thu May 08, 2003 1:22 pm
Hi,
do anybody here have a software for 4 Gen. f-body, to connect it with the car and read all errors, and make diagramms about the engnie, etc.?
I know about this software, but it is to expensive. Can anybody make a "burn" CD for me? :)
After this I can buy a connection cable.
Danix
P.S. Come somebody on Dasing Meeting 18.05.2003?
PostPosted: Fri May 09, 2003 7:20 am
Most of that software has the original VIN number burned into it and it checks for it in the PCM . If it doesn't read the proper VIN then it won't work.
Auto Tap for 200 dollars will read all codes on all OBDII Gm products and reset the light once the problem is corrected. Software is free bit the cable cost.
PostPosted: Mon May 12, 2003 9:17 am
Hi Roy,
are the Auto Tap Software only a Error reader Programm or with digramms about all sensors in the car?
Danix
