| Shell V-Power http://forum.fbodyeurope.org/phpBB3/viewtopic.php?f=11&t=3333 |
Page 1 of 1 |
| Author: | Danix [ Wed May 28, 2003 10:39 am ] |
| Post subject: | Shell V-Power |
Hi! Have anybody test the Shell V-Power gas too? Danix |
| Author: | ott [ Wed May 28, 2003 7:48 pm ] |
| Post subject: | |
Haven't noticed any difference compared to 98. May-be it helps, if you get some knock under heavy load. |
| Author: | Squirrelina [ Wed May 28, 2003 11:47 pm ] |
| Post subject: | |
some said it works, either give it an extra boost or... get 50 km more out of the tank. I also had somebody telling me the american engines were not build for 100 octane, unless you want to replace seals and gaskets ? seems to be for the ricers, heared in Japane the higher octane is standard ? ...now all of that is from others, not me. I did not try yet, my truck takes diesel. |
| Author: | SSZ28 [ Thu May 29, 2003 7:26 am ] |
| Post subject: | |
Bottom line, if you can take advantage of the higher octane to build more power, use it, it WON’T hurt anything. Otherwise, save your money for something else that can make you some ponies under the hood. Blower, nitrous, etc. |
| Author: | ChrisV6 [ Thu May 29, 2003 8:39 am ] |
| Post subject: | |
Good explanation! I agree absolutely about that. Most people still think that higher octane means that the gas has more energy, but thats simply wrong. If you don´t have a higher compression ratio or lots of boost from a turbo or supercharger you simply waste your money on this. OK, they put some additives in it, but if you use some injection cleaner from time to time you should see the same results and save money. |
