| Calibrating needles http://forum.fbodyeurope.org/phpBB3/viewtopic.php?f=11&t=3904 |
Page 1 of 1 |
| Author: | JackZ28 [ Tue Dec 30, 2003 8:38 am ] |
| Post subject: | Calibrating needles |
Anyone know how to do this? I installed my gauges last year, but the needles are all screwed up.. Does Aafes do this? I'd really love to have functioning gauges. |
| Author: | predator [ Tue Dec 30, 2003 8:51 am ] |
| Post subject: | |
i can |
| Author: | Roy [ Tue Dec 30, 2003 4:22 pm ] |
| Post subject: | |
Jack if you got Atap or ls1 edit. u can use that to get your needles close on the all the guages . Just leave the plastic off and hook the connector back in the guage cluster. Bring engine to op temp and set the your temp , bring up voltage , tach and what ever else and readjust the needles as close to the values as possible. for the speedo put the back axle on jackstands , and use yor cruise control and edit to monitor your speed and then adjust your needle. It worked for a couple of friends over here . |
| Author: | JackZ28 [ Tue Dec 30, 2003 4:31 pm ] |
| Post subject: | |
How can I do that with LS1Edit? I'd love to know. |
| Author: | Roy [ Tue Dec 30, 2003 4:41 pm ] |
| Post subject: | |
jack u wil have to move the needles manually , but Iam under the impression that edit will let u see all your vehicle vitals on your laptop. I may be mistaken, I know Atap does . |
| Author: | JackZ28 [ Tue Dec 30, 2003 4:57 pm ] |
| Post subject: | |
Unfortunately, I don't believe it does. It only allows you to change most parameters. |
| Author: | predator [ Tue Dec 30, 2003 9:09 pm ] |
| Post subject: | |
jack ican set those needles for you they will be close enough |
| Author: | JackZ28 [ Tue Dec 30, 2003 9:27 pm ] |
| Post subject: | |
No offense, but I don't want someone to eyeball them. I want them to be dead-on accurate! |
| Author: | predator [ Tue Dec 30, 2003 9:31 pm ] |
| Post subject: | |
uh mine ar accurate i di my guages also |
