| I need some help http://forum.fbodyeurope.org/phpBB3/viewtopic.php?f=11&t=4485 |
Page 1 of 1 |
| Author: | SSZ28 [ Sat Jun 05, 2004 8:49 pm ] |
| Post subject: | I need some help |
Truck ran great all day Friday. Had a hard time starting it that morning though. Had to play with the timing but didn't think anything of it. Got it set where it ran the best and left it at that. Kept starting back up without problems afterwards all day. Here's the problem. Damn thing wouldn't start today. DAMN YOU MURPHY!!! |
| Author: | MadMav [ Sat Jun 05, 2004 10:57 pm ] |
| Post subject: | |
You getting spark at the wires? could be intermitant coil. Mav |
| Author: | Roy [ Sun Jun 06, 2004 4:28 am ] |
| Post subject: | |
Ditto what Mav said |
| Author: | 395stang [ Sun Jun 06, 2004 4:04 pm ] |
| Post subject: | |
hAD THE SAME PROB WITH MY cAMARO . iT HAD A HAIR LINE CRACK IN THE COIL. |
| Author: | SSZ28 [ Sun Jun 06, 2004 10:06 pm ] |
| Post subject: | |
Dang it. The parts are supposed to be new. Thanx for the info, keep it coming. |
| Author: | NXZ28 [ Mon Jun 07, 2004 8:23 am ] |
| Post subject: | Ignition problem |
My 70 Chevelle had the same problem. Did you convert the ignition from Points to HEI? If so, did you change the diameter of the wire running from the starter solenoid to the HEI coil? It needs to be two sizes bigger. The old wire will still read 12 volts but the resistance is two high to provide the power for the HEI. One more thing to check. If you are running a Quadrajet see if the fuel bowl in the carb is empty in the morning. If so give me a call at 01786996831 and I will explain to you how to fix it. |
| Author: | SSZ28 [ Mon Jun 07, 2004 10:26 am ] |
| Post subject: | |
Had a q-jet. Know what you're talking about. A little epoxy works. |
| Author: | SSZ28 [ Mon Jun 07, 2004 7:38 pm ] |
| Post subject: | |
The really f-d up part about all of this is - I'm supposed to be a mechanic. I can fix everything but my own crap. |
| Author: | NXZ28 [ Tue Jun 08, 2004 11:08 am ] |
| Post subject: | |
Try the bigger gauge wire we spoke about. To use it as a quick diagnosis you can run it from the Hot on the alternator to the coil. The only thing is that the car won't shut off until you remove this wire. |
| Author: | NXZ28 [ Tue Jun 08, 2004 11:09 am ] |
| Post subject: | |
| Author: | SSZ28 [ Thu Jun 10, 2004 9:08 pm ] |
| Post subject: | |
Tried it, didn't work. Thanx for all of the input. |
| Author: | MadMav [ Thu Jun 10, 2004 9:37 pm ] |
| Post subject: | |
Glad you got it running again. Send that other crap back. Mav |
