| Jens spring install http://forum.fbodyeurope.org/phpBB3/viewtopic.php?f=11&t=5588 |
Page 1 of 1 |
| Author: | Roy [ Thu Apr 14, 2005 6:34 pm ] |
| Post subject: | Jens spring install |
How did it go ? Did younotice a difference? |
| Author: | Firechicken [ Fri Apr 15, 2005 4:34 am ] |
| Post subject: | |
Roy, When I saw it a couple of weeks ago I would of sworn it was your car (except color).......sat just the same. |
| Author: | Jens [ Fri Apr 15, 2005 6:41 am ] |
| Post subject: | |
It is very nice driving. I was driving on the autobahn with over 240 km/h and it handles perfect. I´m very happy with this suspension. But i did not only changed the shocks and springs, i changed: -lower control arms with relocation brackets -strut tower brace -panhard rod -front upper control arms -front lower control arms What i have to do next, is to change the sway bar at the front. Thanks for asking. You can see it in Bitburg end of april |
| Author: | Jens [ Fri Apr 15, 2005 6:49 am ] |
| Post subject: | |
but the springs at the front are not very low, right? My old springs were lower at the front
| Author: | RTZSS [ Fri Apr 15, 2005 8:01 am ] |
| Post subject: | |
I take it you had the V6 springs on it before? |
| Author: | Jazzy91 [ Fri Apr 15, 2005 10:42 am ] |
| Post subject: | |
What company did you go with for the parts? |
| Author: | Jens [ Fri Apr 15, 2005 12:45 pm ] |
| Post subject: | |
before i have had BG-Springs in my camaro. They were lower. I bought everything used. Shocks and Springs from Roy Lower control arms with relocation brackets, strut tower brace and panhard rod from JackZ28 front upper control arms and front lower control arms from Gunnar Torq Trust II rims with tires from Firechicken F-Body Europe is a good thing for me. Make buisness with the guys here in this forum is perfect for me |
| Author: | Roy [ Fri Apr 15, 2005 5:53 pm ] |
| Post subject: | |
Quote: but the springs at the front are not very low, right? My old springs were lower at the front
The springs are more performance oriented than lowering. They drop the car about an inch. The shocks and springs should be the biggest gain handling since the shocks( the fronts0 were revalved to match springs. Next 2 big handling gains would be a serious alingment and sticky tires at all four corners. |
| Author: | Jens [ Mon Apr 25, 2005 1:12 pm ] |
| Post subject: | |
Yesterday i was driving on the autobahn A43, that is a very bad autobahn. In front of me was a porsche boxster s and it was driving over 250 km/h. It was no problem to follow him with this speed. It is a pleasure to drive with this suspension also on bad streets. Also the BFG G-FORCE tires i bought from Val are very good on the street. I love them. |
| Author: | Firechicken [ Tue Apr 26, 2005 5:11 am ] |
| Post subject: | |
Jens, Brand new BFG G-Force are awesome for all around driving no matter the weather...... |
| Author: | BenZ28 [ Wed Apr 27, 2005 12:33 pm ] |
| Post subject: | |
I second that. I also have the BFG g-force KDW and they're very good tires... Ben |
