| European F-body owners http://forum.fbodyeurope.org/phpBB3/viewtopic.php?f=11&t=5968 |
Page 1 of 1 |
| Author: | Roy [ Mon Aug 15, 2005 4:56 pm ] |
| Post subject: | European F-body owners |
If your Fbody is an export model , do you know if it came with a towing hook mounted to the front or the back of the car . If it did could or can you post a picture of it. I do know it was suspose to be part of the export package. |
| Author: | Firechicken [ Tue Aug 16, 2005 10:15 am ] |
| Post subject: | |
Roy, Are you going to do what you talked about this weekend??? If so I might be able to help out. Let me know. Val |
| Author: | Roy [ Tue Aug 16, 2005 10:59 am ] |
| Post subject: | |
Thinking hard about it |
| Author: | BenZ28 [ Tue Aug 16, 2005 11:02 am ] |
| Post subject: | Re: European F-body owners |
Roy wrote: If your Fbody is an export model , do you know if it came with a towing hook mounted to the front or the back of the car .
Yes, it did. I can try to make a picture but don't know if today... (...and what are you going to do...?) Ben |
| Author: | Roy [ Tue Aug 16, 2005 11:36 am ] |
| Post subject: | |
Ben that would be great when you get a chance . I am not sure what I really really want to do. |
| Author: | Daddy [ Tue Aug 16, 2005 7:37 pm ] |
| Post subject: | |
Firechicken wrote: Roy,
Are you going to do what you talked about this weekend??? If so I might be able to help out. Let me know. Val Huh?? |
| Author: | Roy [ Tue Aug 16, 2005 8:15 pm ] |
| Post subject: | |
Thanks Ben i am posting the picts on Frrax. |
| Author: | BenZ28 [ Wed Aug 17, 2005 2:47 pm ] |
| Post subject: | |
Looks like they want to see the rest of the pictures, I can't post there for some reason... Ben |
| Author: | JackZ28 [ Fri Aug 19, 2005 9:09 pm ] |
| Post subject: | |
Man, there's a 10th anniversary Formula Firehawk at school here, and that sumbiotch has a tow hitch. |
| Author: | Firechicken [ Tue Aug 23, 2005 6:58 am ] |
| Post subject: | |
http://search.cartserver.com/search/sea ... s&GO=GO%21 check that Roy, it is $102 rated for 2000lbs w a tongue wt of 200lbs. DrawTite Hitches is the maker. |
