| seems i need a stronger rear axle http://forum.fbodyeurope.org/phpBB3/viewtopic.php?f=11&t=6384 |
Page 1 of 1 |
| Author: | jeejee [ Mon Mar 06, 2006 8:49 pm ] |
| Post subject: | seems i need a stronger rear axle |
apperently 320Hp at the wheels is the absolute limit a (strengthend) opel axle will stay together.. eventhough i have allways used only street tires. i think i'm quite lucky it didn't break like roys.. the pinion axle was allso completely bend
| Author: | Garry [ Mon Mar 06, 2006 9:01 pm ] |
| Post subject: | |
Whoa! |
| Author: | Roy [ Mon Mar 06, 2006 9:27 pm ] |
| Post subject: | |
If you use reverse you can straighten it. |
| Author: | Firechicken [ Tue Mar 07, 2006 8:42 am ] |
| Post subject: | |
Damm...atleast you had fun doing it!!! |
| Author: | SRZ [ Tue Mar 07, 2006 9:11 am ] |
| Post subject: | |
Yoasah! Nice reason to upgrade as always. |
| Author: | Firechicken [ Tue Mar 07, 2006 1:56 pm ] |
| Post subject: | |
JeeJee call Moser and give them the dimensions of your current axle housing and have them build you a 9in ford for it, you won't have to worry about breaking it then!! |
| Author: | jeejee [ Tue Mar 07, 2006 10:34 pm ] |
| Post subject: | |
Val, I think a 9 inch is perhaps a bit over the top I've been looking at a 10 bolt but i don't really like c clips i know you can get an eliminator kit for it, but i might be better of with perhaps a DANA. there easy to come by here in europe (eg. volvo) And parts are easy to get from summit i only wonder if the european dana's are metric and the stuff from summit imerial ?? |
| Author: | Firechicken [ Wed Mar 08, 2006 2:57 pm ] |
| Post subject: | |
Not sure on the Dana Euro spec or not but I'm sure that Summit can get the parts. |
| Author: | Roy [ Wed Mar 08, 2006 3:26 pm ] |
| Post subject: | |
JeeJee Do a Dana Volvo google search. Plenty of info out there. |
| Author: | jinstall [ Sat Mar 11, 2006 10:59 am ] |
| Post subject: | |
Better get a Dana while yo can GM just dropped them and I think they might be in trouble. |
