It is currently Tue Aug 25, 2026 12:05 pm
 Post subject: So close, yet so far away
PostPosted: Wed Jun 07, 2006 12:25 pm
F-bodies and Vettes have the same bolt patter for the wheels, but the f-body hub is just slightly (not so much that you would ever notice) larger. Why does this matter. Aftermarket wheels are usually made to fit all 3 so if they use an f-body hub, it'll work fine of the vettes and they can sell more wheels. This also means that wheel spacers are made with f-body size hubs. Why do I know all of this. I got good new tires for my OEM wheels and went to put them on the car last night only to find they didn't fit over the spacers hub.
:hammer:
I swear, if it wasn't for bad luck, I would have no luck at all.
PostPosted: Wed Jun 07, 2006 12:33 pm
rotten luck ... sorry man ... :(
PostPosted: Wed Jun 07, 2006 4:30 pm
I don't know about that I got Vette specific rims and they go on the hub quite nicely.
PostPosted: Wed Jun 07, 2006 4:53 pm
See you should get a F-body then and then the problems would be solved.
PostPosted: Wed Jun 07, 2006 6:53 pm
Are they OEM or aftermarket - both my Z06 and C4 GS wheels fit fine, but they're aftermarket replicas.
PostPosted: Wed Jun 07, 2006 7:46 pm
Factory.
There is another guy that is running factory Corvette rims on his red Fbody also.
PostPosted: Wed Jun 07, 2006 7:47 pm
Keith are you sure its not just the spacer causing the problem?
PostPosted: Wed Jun 07, 2006 9:03 pm
yeah, the hub on the spacer is to big. That's the problem. It works with both of my aftermarket sets of wheels, but not the OEM wheels.
Users browsing this forum: No registered users and 47 guests
