| failed inspection http://forum.fbodyeurope.org/phpBB3/viewtopic.php?f=11&t=7407 |
Page 1 of 2 |
| Author: | a10beav [ Mon May 14, 2007 4:05 pm ] |
| Post subject: | failed inspection |
I need a new tie rod end, but I'll order that tonight. I need an on/off switch for the foglights; where are auto parts stores in K-town? The exhaust is too loud, 101db. I had some steel wool in the exhaust, but I don't think I can cram enough in there to pass inspection. I've been looking at bullet mufflers, but Dynomax only advertises a 2-4db change and the other brands seem too large. I already have low exhaust in the front and I don't want more problems. I'm debating a new muffler because of that. Gary, do you still have the stock exhaust on the Hawk? And finally, I need to remove the front window tint. Oh well, I guess it could have been worse... |
| Author: | Garry [ Mon May 14, 2007 4:59 pm ] |
| Post subject: | |
Yes, stock Firehawk that is ... |
| Author: | mpsolo [ Mon May 14, 2007 5:30 pm ] |
| Post subject: | too loud |
Man I failed with 103 db so I stuffed a bag of steel wool in each pipe and it got so quiet I didn't get a db test the second time. Good luck!!! |
| Author: | a10beav [ Mon May 14, 2007 5:45 pm ] |
| Post subject: | |
I emailed a few companies and Moroso says I could see about around a 7db decrease. It doesn't look too restricitive either. I don't see how you can fit a whole bag in each pipe, seems like it would blow right out! |
| Author: | jinstall [ Mon May 14, 2007 7:14 pm ] |
| Post subject: | |
The More the better, it does the trick. I use Supetrapp so I can adjust the sound witht he disc as needed. |
| Author: | Roy [ Mon May 14, 2007 7:38 pm ] |
| Post subject: | |
Yes the steel wool works . But you want the wool in there as loose as possible with out it blowing out . also be gentle on the gas pedal . |
| Author: | a10beav [ Mon May 14, 2007 8:12 pm ] |
| Post subject: | |
I was pretty gentle on the pedal, but the inspector jumped in the seat and blipped the throttle a few times before running it up. I crammed some wire mesh behind the wool to hold it in place, and it held but I didn't have that much wool in there. Right now I'm thinking about adding a Moroso resonator. It's only 4" in diameter and should give enough db reduction. I'll probably add steel wool again, just to make sure. |
| Author: | Fast GTO [ Tue May 15, 2007 5:19 am ] |
| Post subject: | |
You need to take your car somewhere other than the Ramstein area...... |
| Author: | a10beav [ Tue May 15, 2007 6:40 am ] |
| Post subject: | |
Like where? Is Spangdahlem any better? |
| Author: | TurboManiacal [ Tue May 15, 2007 9:21 pm ] |
| Post subject: | |
Don't let the inspector do it is all I can say. |
| Author: | Fast GTO [ Fri May 25, 2007 1:28 am ] |
| Post subject: | |
Try to find an Army base. I know Schweinfurt is easy, my Goat passed. |
| Author: | a10beav [ Fri May 25, 2007 11:34 pm ] |
| Post subject: | |
I actually failed the inspection at Vogelweh, is the Ramstein shop the same? I just got a Moroso spiral flow that I was going to add to the I-pipe, they're supposed to be low resistance but reduce the db by 7. I hate to add it, but I am tired of the "rifling" during deceleration, so maybe this will help... |
| Author: | KC10A [ Sat May 26, 2007 9:23 am ] |
| Post subject: | |
The Vogelweh inspectors are a bunch of a$$holes. Ramstein isn't that bad. |
| Author: | TurboManiacal [ Sat May 26, 2007 4:32 pm ] |
| Post subject: | |
I'm up next...my car's not that loud...should be okay. |
| Author: | Kenkaru [ Fri Jun 22, 2007 9:07 am ] |
| Post subject: | |
I installed a silencer in the I-pipe and then stuffed a bunch of steel scrubby pads in there upstream of the silencer. It was so quiet, they didn't test me 2nd time through. Plugging up one of the tailpipes makes a large reduction also. |
| Author: | TurboManiacal [ Mon Jun 25, 2007 6:08 pm ] |
| Post subject: | |
TurboManiacal wrote: I'm up next...my car's not that loud...should be okay.
Stock LS1 w/ Resonators = 96db - 1 over the limit (Mannheim allows 95 for whatever reason) So steal wool time. |
| Author: | Garry [ Mon Jun 25, 2007 6:46 pm ] |
| Post subject: | |
Hm ... just noticed this weekend that at idle, my Firehawk (stock all the way through) is actually a bit louder than Roy's SS ... So I reckon it would most likely not pass the US inspection ... |
| Author: | a10beav [ Mon Jun 25, 2007 7:13 pm ] |
| Post subject: | |
You don't have the SLP Loudmouth installed, do you? I have the spiral flow in teh I-pipe now. It still sounds Ok and it has taken care of the rifling, but I miss the more aggressive sound. |
| Author: | Garry [ Mon Jun 25, 2007 7:48 pm ] |
| Post subject: | |
Nope, Stock Firehawk exhaust ... |
| Author: | Chevroletfreak [ Mon Jun 25, 2007 8:52 pm ] |
| Post subject: | |
A10- did you ever pass? |
| Page 1 of 2 | All times are UTC + 1 hour |
