It is currently Tue Aug 25, 2026 10:23 am
 Post subject: Got the head pulled off the Sierra finally.
PostPosted: Sat Sep 08, 2007 6:29 pm
It looks like the valves were playing kissy face with the pistons.
The Biatch steh bolts
PostPosted: Sat Sep 08, 2007 6:36 pm
Ouch ...
PostPosted: Sun Sep 09, 2007 10:51 am
Finally. Did you have to move the engine around a bit to get them off?
PostPosted: Sun Sep 09, 2007 2:22 pm
Just use a engine hoist to get a good pull on it .
PostPosted: Sun Sep 09, 2007 11:10 pm
allmost all the original pistons have kissing marks on them not to worry...
throw away the stehbolzen and use the ORIGINAL ford head bolts, these seem to work better....
(and a lot easier to get the head off next time ;-)
only problem with using these is there are no locater dowels for the head in the block, so be carefull when installing the head.
i had problems with the post motorsport head studs, now with the normal ford bolts, i haven't had a problem yet
