It is currently Tue Aug 25, 2026 5:32 am
 Post subject: She's gone and I'm out!
PostPosted: Wed May 28, 2008 7:35 am
PEACE!
The "SRZ"
 Post subject: Re: She's gone and I'm out!
PostPosted: Wed May 28, 2008 7:51 am
Hope you put a rev limiter in at 1500 or so ...
PostPosted: Wed May 28, 2008 9:51 am
Pretty close......1800.
Dang they put that right under a leaky Ford. LOL
Nice 4x4 stance too.
PostPosted: Wed May 28, 2008 9:59 am
If it oils enough, it should keep the corroding water away ;)
John, will you be able to come to Bitburg next time for a little good-bye BBQ?
PostPosted: Wed May 28, 2008 11:09 am
Yep, 1800rpms'. I probably should've gone lower esp w/ stump pulling torque @ over 500lb ft @ 2000 rpm's but it doesn't matter. She's only good for maybe 2 more startups as the tank is that low. :D She'll burn a fuel pump before you do any mechanical damage if it came down to it.
Garry, I SHOULD be able to make it that Sat the 7th but no promises as we're closing on our house on the 6th.
Brian, she's up there in the air for sure. :D Feels like a truck now. ha-ha.
Leaky Ford? I can leak, I'm more worried about the hydraulics failing and crushing my car! :shock:
The "SRZ"
PostPosted: Thu May 29, 2008 12:43 am
Have a good move! Too bad I never got to see the car.
PostPosted: Fri May 30, 2008 10:17 pm
Hell! Its amazing to see it off of jack stands!
Give me a call when you get back to the states! 501 350-2314
PostPosted: Tue Jun 03, 2008 10:24 pm
Good back !
Maybe one day I will come see you at your new home ;-)
http://www.MuscleCarsAndCo.com
PostPosted: Thu Jun 05, 2008 10:06 am
Come on down Francis. :) I'll be looking for some classics for you while there too. ;)
The "SRZ"
