It is currently Mon Aug 24, 2026 12:45 am
 Post subject: Need some boost?
PostPosted: Thu May 21, 2009 8:11 am
Z06 too slow? ZR1 not enough HP? Well, guess you could always get you this 'vette (German article)
 Post subject: Re: Need some boost?
PostPosted: Thu May 21, 2009 8:21 am
Scheiße! Even with the crazy colors, I would rock that! Now I just need 190k Euros!
PostPosted: Thu May 21, 2009 8:26 am
Not sure if I'd really like that LS7 bored to 7.6L PLUS twin turbo ... the ZR1 might be the slightly safer way to go ... ;)
PostPosted: Thu May 21, 2009 8:31 am
Is that because of the length of the bore? I thought the LS9 had a longer bore....specifically for the supercharger.
PostPosted: Thu May 21, 2009 9:06 am
Yeah, probably some of both ... ~.08L per cylinder is probably more than you could bore it over ...
