It is currently Mon Aug 24, 2026 4:44 pm
 Post subject: Prepping Fiberglass
PostPosted: Mon Nov 02, 2009 6:44 pm
Does anyone have special techniques/warnings when prepping fiberglass? I know a lot of sanding and from what i read, use paint to find the high spots. anything else would be appreciated.
See it, Hear it, Feel it!!
 Post subject: Re: Prepping Fiberglass
PostPosted: Mon Nov 02, 2009 7:45 pm
I just tried my first real fiberglass attempt. The main thing I found is that it is tough to get the hardner mix right because of all of the different variables. To me it seemed like I was using way too much hardner, but it worked out well....just gotta be quick. I also used a lot of tape to make sure it did not get where I did not want it.
The main thing I could not figure out is how to get the mat to lay where I wanted it. As soon as I got it wet it would fall apart. This was especially true when trying to work with an inward/upside down curve. There has to be some sort of trick with that.
PostPosted: Mon Nov 02, 2009 8:34 pm
Be carefull with wet sanding...... fibreglass is hygroscopic, it sucks water and could ruin your paint job if not dried properly.
PostPosted: Mon Nov 02, 2009 11:22 pm
When you are through sanding, or getting ready to put another layer on, wipe it down with acetone.
PostPosted: Wed Nov 04, 2009 9:22 pm
Thanks everyone, I am gonna try it out....now the time to do it W/O a garage
