| Sold the Goat decided to try out a Termi... http://forum.fbodyeurope.org/phpBB3/viewtopic.php?f=11&t=8604 |
Page 1 of 2 |
| Author: | Fast GTO [ Wed Nov 25, 2009 3:02 pm ] |
| Post subject: | Sold the Goat decided to try out a Termi... |
Well I will be back in Germany come JUN. Going to try out the road courses this time around with a Termi since I am going to be pretty close to Hockenheim. Look forward to coming back. This is the car, 2.2KB Terminator: http://www.svtperformance.com/forums/te ... h-ann.html ![]()
| Author: | Roy [ Wed Nov 25, 2009 5:07 pm ] |
| Post subject: | Re: Sold the Goat decided to try out a Termi... |
Looks good. What does it have for suspension, brakes, horsepower and of course tires? |
| Author: | Fast GTO [ Wed Nov 25, 2009 6:02 pm ] |
602rwhp on 93 pump gas. Going to be getting an AEM meth kit installed and a new 91 and 93 Octane tune along with a larger radiator. Once I actually learn to drive it well I'm going to add the Cobra R brakes and coilovers. Need to improve the driver first. Mods currently: 2.2 Polished Kenne Bell supercharger Polished kenne bell ported intake 1600 CFM Throttle Body Kenne bell B.A.P 55#Fuel Injectors 2.93 upper pulley 3-piece idler pulleys (Anodized Red) Denso Spark plugs Bassani headers, x pipe and catback (full exhaust) C.A.I open Conical Air Filter with stainless heat Gaurd Gords Ford Aluminum heat exc M.M.S full sub frame connectors M.M.S drive shaft safety loop M.M.S IRS bushings M.M.S rear end bushings M.M.S Casrer camber platers M.M.S strut tower brace H.P.B.H supercharger catch can polished Steeda Tri Ax shifter Steeda IRS brace spec stage 3 clutch 26input shaft autometer Boost/fuel pressure Livemoise chop and dyno-tune |
| Author: | Roy [ Wed Nov 25, 2009 7:27 pm ] |
Should be very exciting |
| Author: | Fast GTO [ Wed Nov 25, 2009 7:51 pm ] |
Found a really good brake duct cooling kit for $150ish, probably going to get that at a minimum before the first track event. I'll be looking for a mentor if anyone is willing. I'm new to racing a manual and new to open track. Going to be fun! ![]() ![]()
| Author: | jeejee [ Thu Nov 26, 2009 12:11 am ] |
nice ride ! whats the blue aeroquip connection on the kenne bell snout ? some sort of extra lubrication ? looks a bit like an accusump ? |
| Author: | BenZ28 [ Thu Nov 26, 2009 10:04 am ] |
Nice car! Looking forward to seeing you at Hockenheim and other tracks. |
| Author: | Fast GTO [ Thu Nov 26, 2009 12:17 pm ] |
I'm looking forward to learning. Not sure what the braided line going into the snout is for. Can't imagine it being for anything other than oiling. |
| Author: | Fast GTO [ Mon Nov 30, 2009 9:17 am ] |
Anyone know the rules for mounting the front license plate? Can I put it clearly in the front windshield. Not really wanting to drill holes in the front bumper or cover up the intercooler. |
| Author: | BenZ28 [ Mon Nov 30, 2009 9:26 am ] |
Fast GTO wrote: Anyone know the rules for mounting the front license plate? Can I put it clearly in the front windshield. Not really wanting to drill holes in the front bumper or cover up the intercooler. I know that putting it in the windshield is not legal. |
| Author: | Fast GTO [ Mon Nov 30, 2009 10:11 am ] |
Thanks, kind of figured that. Need to get creative now. |
| Author: | a10beav [ Wed Dec 02, 2009 5:17 pm ] |
Have fun with the car. You can use the SLP 4th gen Camaro license plate frame, its really a multi-purpose mount. It'll mount on the opening for the intercooler, but on the horizontal side, and the plate will sit in the stock location (in front of the bumper). |
| Author: | SRZ [ Wed Dec 02, 2009 9:42 pm ] |
Build an L bracket and attach it to the underside of the lower fascia. The holes won't be visible then. |
| Author: | hotrodredneck [ Sun Dec 06, 2009 12:15 am ] |
yep....you can build a bracket for it. Talk to road warrior on my site and i forget his username on mighty. Nice ride!! what did you do with the gto? Also dont forget to check out my site for more stang related stuff militarystangs.com |
| Author: | Fast GTO [ Sun Dec 06, 2009 5:16 pm ] |
Anyone know if you can get bottles of HEET in Germany for a meth kit? |
| Author: | hotrodredneck [ Mon Dec 07, 2009 2:41 am ] |
ask trevor....he is the only one I know of that used it in Germany |
| Author: | Chevroletfreak [ Mon Dec 07, 2009 12:01 pm ] |
Trevor = bahndrvr. He is actually back stateside, but stops in here occasionally. So, Heet is Meth or is it some sort of additive? I'm n/a obviously. |
| Author: | hotrodredneck [ Tue Dec 08, 2009 2:57 am ] |
he's a regular on my place too. |
| Author: | Fast GTO [ Wed Dec 09, 2009 12:26 pm ] |
I was told they sell Heet at the gas station shopette's. FYI |
| Author: | TurboManiacal [ Wed Dec 16, 2009 4:00 am ] |
My corvette is faster...much faster. |
| Page 1 of 2 | All times are UTC + 1 hour |
