It is currently Tue Aug 25, 2026 7:48 am
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
 Post subject: Sold the Goat decided to try out a Termi...
PostPosted: Wed Nov 25, 2009 3:02 pm
Well I will be back in Germany come JUN. Going to try out the road courses this time around with a Termi since I am going to be pretty close to Hockenheim.
Look forward to coming back.
This is the car, 2.2KB Terminator:
http://www.svtperformance.com/forums/te ... h-ann.html
Full Bassani Exhaust
AEM Meth Injection
 Post subject: Re: Sold the Goat decided to try out a Termi...
PostPosted: Wed Nov 25, 2009 5:07 pm
Looks good.
What does it have for suspension, brakes, horsepower and of course tires?
PostPosted: Wed Nov 25, 2009 6:02 pm
602rwhp on 93 pump gas. Going to be getting an AEM meth kit installed and a new 91 and 93 Octane tune along with a larger radiator.
Once I actually learn to drive it well I'm going to add the Cobra R brakes and coilovers. Need to improve the driver first.
Mods currently:
2.2 Polished Kenne Bell supercharger
Polished kenne bell ported intake
1600 CFM Throttle Body
Kenne bell B.A.P
55#Fuel Injectors
2.93 upper pulley
3-piece idler pulleys (Anodized Red)
Denso Spark plugs
Bassani headers, x pipe and catback (full exhaust)
C.A.I open Conical Air Filter with stainless heat Gaurd
Gords Ford Aluminum heat exc
M.M.S full sub frame connectors
M.M.S drive shaft safety loop
M.M.S IRS bushings
M.M.S rear end bushings
M.M.S Casrer camber platers
M.M.S strut tower brace
H.P.B.H supercharger catch can polished
Steeda Tri Ax shifter
Steeda IRS brace
spec stage 3 clutch
26input shaft
autometer Boost/fuel pressure
Livemoise chop and dyno-tune
AEM Meth Injection
PostPosted: Wed Nov 25, 2009 7:27 pm
Should be very exciting
PostPosted: Wed Nov 25, 2009 7:51 pm
Found a really good brake duct cooling kit for $150ish, probably going to get that at a minimum before the first track event.
I'll be looking for a mentor if anyone is willing. I'm new to racing a manual and new to open track. Going to be fun!
AEM Meth Injection
PostPosted: Thu Nov 26, 2009 12:11 am
nice ride ! :shock:
whats the blue aeroquip connection on the kenne bell snout ? some sort of extra lubrication ? looks a bit like an accusump ?
PostPosted: Thu Nov 26, 2009 10:04 am
Nice car!
Looking forward to seeing you at Hockenheim and other tracks. :)
PostPosted: Thu Nov 26, 2009 12:17 pm
I'm looking forward to learning.
Not sure what the braided line going into the snout is for. Can't imagine it being for anything other than oiling.
AEM Meth Injection
PostPosted: Mon Nov 30, 2009 9:17 am
Anyone know the rules for mounting the front license plate? Can I put it clearly in the front windshield. Not really wanting to drill holes in the front bumper or cover up the intercooler.
AEM Meth Injection
PostPosted: Mon Nov 30, 2009 9:26 am
I know that putting it in the windshield is not legal.
PostPosted: Mon Nov 30, 2009 10:11 am
Thanks, kind of figured that. Need to get creative now.
AEM Meth Injection
PostPosted: Wed Dec 02, 2009 5:17 pm
Have fun with the car. You can use the SLP 4th gen Camaro license plate frame, its really a multi-purpose mount. It'll mount on the opening for the intercooler, but on the horizontal side, and the plate will sit in the stock location (in front of the bumper).
PostPosted: Wed Dec 02, 2009 9:42 pm
Build an L bracket and attach it to the underside of the lower fascia. The holes won't be visible then.
The "SRZ"
PostPosted: Sun Dec 06, 2009 12:15 am
yep....you can build a bracket for it. Talk to road warrior on my site and i forget his username on mighty. Nice ride!! what did you do with the gto? Also dont forget to check out my site for more stang related stuff militarystangs.com
PostPosted: Sun Dec 06, 2009 5:16 pm
Anyone know if you can get bottles of HEET in Germany for a meth kit?
AEM Meth Injection
PostPosted: Mon Dec 07, 2009 2:41 am
ask trevor....he is the only one I know of that used it in Germany
PostPosted: Mon Dec 07, 2009 12:01 pm
Trevor = bahndrvr. He is actually back stateside, but stops in here occasionally.
So, Heet is Meth or is it some sort of additive? I'm n/a obviously.
PostPosted: Tue Dec 08, 2009 2:57 am
he's a regular on my place too.
PostPosted: Wed Dec 09, 2009 12:26 pm
I was told they sell Heet at the gas station shopette's. FYI
AEM Meth Injection
PostPosted: Wed Dec 16, 2009 4:00 am
My corvette is faster...much faster.
