It is currently Sat Oct 24, 2026 12:27 pm
 Post subject: Owned the camaro for 14 years and 80,000 miles
PostPosted: Fri Feb 17, 2012 9:30 pm
Time for some neglected maintenance
Replacing all bearing pulleys
Replacing all coolant hoses
Inspecting everything else
Basically everything else has been replaced or serviced or dranied and filled on schedule.
That is all.
 Post subject: Re: Owned the camaro for 14 years and 80,000 miles
PostPosted: Mon Feb 20, 2012 9:55 am
My car now is over 13 years old (manufactured in October 1998) and has also just over 80000 miles.
I did the pulleys last November (ah not all, I just remember I still have to do the two A/C pulleys).
The coolant hoses "look" still pretty good, I do not see any cracks or that the rubber is becoming too stiff. Is this the case with yours? Or do you just replace them because of their age generally?
The rest has also been changed regularly in my car -- except for the clutch fluid. Well, this will be done when I'll finally do the clutch next month...
PostPosted: Mon Feb 20, 2012 1:32 pm
Ben for hoses you are correct cracks, stiffen of the rubber plus swelling, sponginess on the exterior. Its the interior of the hoses that you can't really be too sure of after years of service and the abuse of high coolant temps when doing track days . I am going to be safe than sorry. Nothing to be alarmed about , some folks are just fine replacing hoses only when the hose bursts.
PostPosted: Mon Feb 20, 2012 3:41 pm
You're right about the interior of the hoses... I might be replacing mine then, too. I don't want to experience a failure on a track day or generally when driving around...
PostPosted: Wed Feb 22, 2012 9:35 am
Roy, will you use stock hoses or some special aftermarket stuff?
PostPosted: Wed Feb 22, 2012 6:35 pm
I am sticking with the stock stuff from Dayco.
PostPosted: Fri Apr 06, 2012 2:29 pm
Did you buy them at a local place or somewhere else (Rockauto for example)? Could you point me to the correct stuff, I see several different hoses and no complete package...?!
PostPosted: Sat Apr 07, 2012 8:58 am
Part Number/Part Type Price EA QTY Total
1998 CHEVROLET CAMARO 5.7L V8
ACDELCO RC94 Radiator Cap $ 7.24 1 $ 7.24
DAYCO 87001 Heater Hose $ 8.84 1 $ 8.84
DAYCO 5060790 Belt $ 17.69 1 $ 17.69
DAYCO 71982 Radiator Lower Hose $ 4.37 1 $ 4.37
DAYCO 89135 Tensioner Pulley $ 11.40 2 $ 22.80
DAYCO 80411 Heater Hose $ 6.47 1 $ 6.47
DAYCO 5040410 Belt $ 8.49 1 $ 8.49
DAYCO 87716 Heater Hose 7.32 2 $ 14.64
DAYCO 70704 Radiator Upper Hose $ 5.16 2 $ 10.32
DAYCO 89015 Tensioner Pulley $ 9.31 1 $ 9.31
DAYCO 80400 Heater Hose $ 6.32 1 $ 6.32
DAYCO 89159 Idler Pulley $ 22.99 1 $ 22.99
DORMAN 603116 (603-116) Coolant Recovery Tank $ 22.79 1 $ 22.79
DORMAN 56390 Coolant Water By-Pass Gasket $ 4.64 1 $ 4.64
From Rock Auto
PostPosted: Tue Apr 17, 2012 8:21 pm
Hmmmm, this reminds me... My hoses are all good but I need to do a coolant flush...
Thanks for the reminder guys!
Side note: When you coming out with us again Roy?
Scott
2000 SS A4 Arctic White (only 39k on the clock).
