It is currently Tue Aug 25, 2026 2:17 am
 Post subject: ASP under drive pullies w belts
PostPosted: Mon Jun 23, 2003 7:05 am
I have the ASP underdrive crank 25% underdrive and altenator pulley another+10% for just altenator with gator back belts 2 ea one for the alt and WP and one for the AC pump. power gains are about 10 hapees but saves where you save wear and tear on acc with this. I paid almost 300 - shipping for the complete set up. I would like to get $190 for it.
PostPosted: Mon Jun 23, 2003 7:16 am
Hey Bruce, add that to my tab.. Send 'em to me and I will send you $390 when I get back from Southern France. I leave tomorrow.
I found a broken spring, so that was probably the culprit. Are those the stock lifters you sent me? They look way better than the ones I had.. Totally different..
PostPosted: Mon Jun 23, 2003 7:35 am
OK. So it was a spring that could a been a 30 min job. Jack replace that one only spring only I will send ya another set of used 941 4ea broken and call katech he will send you a new set get the CC 918 They are alot better this will get you up and running until the 918 get here. BTW tell them you need 16 steel retainers. Any questions call me DSN 475 8162 or 09662-83 8162.
PostPosted: Mon Jun 23, 2003 7:37 am
They are 01 OEM with about 10,000 miles on them.
PostPosted: Mon Jun 23, 2003 8:23 am
I don't know for sure if that was the problem, but if it was, I admit that I am AN IDIOT.. :) Oh well, those lifters you sent me are at least 10 times better, so I don't feel too bad about it.. :oops: :oops:
PostPosted: Mon Jun 23, 2003 9:07 pm
Sounds like the car isn't for sale now. That is good. I would hate to see you sell it. When will you have it running? Let me know when you are ready to go out cruising.
PostPosted: Mon Jun 23, 2003 9:43 pm
I got one head on so far. When I get back from Southern France, I will finish it, and I will cruise with you Jerry..
PostPosted: Tue Jun 24, 2003 7:13 am
good luck give me a call if you get stuck.
