It is currently Mon Aug 24, 2026 11:46 pm
 Post subject: New alternator
PostPosted: Mon May 28, 2001 11:11 am
Im still trying to sell my new alternator, never used, ordered through autozone.com with warrenty. Its Delco Remy CS type, 105 amps and will work on any GM motor 88-94. Might be nice to have one on hand, AAFES doesnt have them without a "Special order from States" -yeah right. I had it as a back up, but since Im going back to the convenience of the states, thought someone else could benefit...$70.
91 black Z28
ON ITS WAY TO USA!!
PostPosted: Fri Jun 08, 2001 10:23 am
...$60!
91 black Z28
ON ITS WAY TO USA!!
PostPosted: Fri Jun 08, 2001 11:29 am
well, I dunno, I heard on cz28.com that by bypassing your alternator you gain 20-30hp, so I'm thinking on removing mine entirely!!! Just stocking up on Optima's. :)
PostPosted: Fri Jun 08, 2001 6:08 pm
Your right!! Plus you get to ditch some weight. All you really have to do is bring a battery charger with you and just plug in your car whenever you stop. Piece of cake, for 30 HP. :)
PostPosted: Mon Jun 11, 2001 1:38 pm
If you have seen the amplifiers Im running in the back, youd probably say keep the alternator, you'll need it! Im just tryin to look out and sell it to someone here so they're not SOL like myself when your alt goes bad and you gotta wait 4 weeks through AAFES or online w/ core charge. With an AutoZone on every corner, I wont need it!
91 black Z28
ON ITS WAY TO USA!!
PostPosted: Sat Jun 16, 2001 8:57 pm
Sold!!
