It is currently Tue Aug 25, 2026 8:32 am
 Post subject: Need a set of front shocks
PostPosted: Wed Jun 30, 2004 5:01 am
I need a set of front shocks with a quickness so if anyone has a set left over from doing a spring shock upgrade or just has a set they decided not to use, I could really use a set.
Did a spring upgrade and had a problem getting off the nut on the shock stem, ended up having to drill off the nut and ruining the shock in the process.
Thanks in advance
John
Black 94 Z28
Purple 92 RS
Silver 91 RS
