It is currently Tue Aug 25, 2026 4:01 am
 Post subject: Gauging interest in 4" exhaust
PostPosted: Sat Apr 08, 2006 12:04 am
I'm thinking about putting my true duals back on so I need to see if I can sell my current set up.
The setup is:
two 3" Magnaflow cats
3" Mufflex Y-pipe that merges with a 3-3-4" Y merge
4" Mufflex I pipe that goes over the axle
Custom 4" in, dual 3" out Spintech muffler
The setup has pipes that exit the rear but they aren't chrome or anything so you'd probably want to get some tips put on eventually.
Both 3" pipes exit on the driver side rear, not like a Trans Am. For this reason, it is more suitable for a Camaro, Formula, or Firebird V6. I have it on my Formula currently.
The cats and whole setup has maybe 3,000 miles on it. I bought the whole thing because I thought my true duals would be illegal over here.
I would be looking to get $700 US for the complete setup.
Here's the Y-pipe except mine has catalytic converters welded in:
http://www.mufflex-performance.com/fbody_8.html
Here's the rest except my muffler is different. Both tailpipes are the same side:
Look at the 98402C-DT
http://www.mufflex-performance.com/fbody_6.html
