It is currently Mon Aug 24, 2026 11:48 pm
 Post subject: Spec stage 2 clutch for LS1/LS6
PostPosted: Sun Mar 05, 2006 7:35 pm
I'm selling a Spec stage 2 clutch for 98-02 F-Bodies / C5-Z06 Corvettes.
See http://www.specclutch.com for details.
The clutch is rated 530 Ft lbs (680 Nm).
It includes: billet steel flywheel, clutch disk and pressure plate.
No Throw out bearing, no pilot bearing, no alignment tool.
I drove it only 500 miles, I then removed it because it chatters and it's out of balance. The flywheel has to be resurfaced, balanced and the assembly has to be balanced too (flywheel + pressure plate).
I haven't done those jobs because I had to have the car on the road the same day, so I reinstalled the stock clutch :cry:
I'm asking 400 Swiss Franks + shipment (about $300)
Thanks - Stefano
1998 convertible Trans Am
MODS: A4 > M6 conversion, SC raptor hood, Vortech V9 G-Trim SQ, homemade water-alcohol injection, Strano sway bars, Koni SA shocks
DYNO: 410 RWHP, 417 RWTQ @ 5 PSI
