It is currently Tue Aug 25, 2026 6:13 am
 Post subject: Tranny / Wheels
PostPosted: Fri Aug 25, 2006 7:18 am
Have 4 stock 1993 trans am wheels for sale. They look like they are in excellent condition. I think they are 16x8" $100 obo
Also have a 700r4 out of my 1988 Trans Am for sale. This is the crossover year for the stronger trannys so if you broke a pre '88 one, this one is better. It has about 3k on it before it was pulled for a T-56. Has a corvette servo, Transgo shift kit, Govener spring kit to move the shift point to 6000 rpm, B4C upshift valve so it shifts into over drive at WOT. Includes corvette 2050 rpm stall converter, flex plate, starter and black powdercoated crossmember with integrated driveshaft loop from Steve Sphon. Had an issue with the servo sticking on it occasionally. This prevented it from shifting at high throttle openings when it happened. Not sure if it will still do it or not. Talked to my tranny guy and he suggested a rebuild kit for the servo. I bought the kit but never installed it so the kit is included also.
$400 / Make offer.
Also have a heavy duty Bosh 8" grinder, $50 / offer
Free Standing (halogen?) shop light $10 / offer
Cheepo Jig Saw $10 / offer
Cheepo one speed no reverse drill $5
2 220v extension chords $10 / offer
Heavy duty 2x4 construction 8' work bench $40 / offer
Metal / particle board work bench / shelving unit $20 / offer
1500w transformer $10
Misc cleaning supplies... take your pick if you buy something. Will let the lot of tools / benches go for $100.
Garage space may also available for rent. 100 euro / month, 20' x 20' bay in a 8 bay garage currently rented by all americans. I'll put you in touch with the lease holder if your interested.
Everything is located in Gieselburg, about 12 miles south of Kaiserslautern.
Please send your requests to d_workman@hotmail.com
