It is currently Tue Aug 25, 2026 1:28 am
 Post subject: Custom camshaft kit for LT1 engines
PostPosted: Sun Feb 04, 2007 1:41 pm
Custom camshaft kit for LT1 engines.
It is custom made by Combination Motorsports. Quite an aggressive camshaft which still provides relatively tame lobe. The parts are high quality made, new and were never installed.
Part list:
Comp Cams LT1 XFI Camshaft, 224/230,.573/.568, 114 LSA
Comp Cams Pro Magnum Roller Rockers, 1.6
Ratio Self Aligning, 3/8’Stud
Comp Cams LS1 918 Valve Springs
Comp Cams Spring Locators for 918 Style Spring,
NON-LS1, For 10 Degree Locks
Comp Cams 10 Degree Super Lock 11/32’
Blue Band Valve Seals LT1
Felpro Intake Manifold Gasket set for LT1
Felpro Timing Cover Gasket Set LT1
EX Components Hardened Pushrods, Black Oxide
7.200’ length, stock for LT1 and LT4
Comp Cams ‘R’ Series Hydraulic Roller Lifters for All small block Chevy w/ Factory Hydraulic Rollers
GM LT1 Crank Timing Gear
GM LT1 Timing Gear, Cam
GM LT1 Timing Chain
Asking $ 1.200,- USD
If you are interested, send me a mail to AlexBanker@Hotmail.com or PM me.
