It is currently Mon Aug 24, 2026 10:51 pm
 Post subject: There is a 94 formula for sale
PostPosted: Fri Jul 20, 2007 8:42 pm
it is located in Heidelberg. He wants 3800 for it. Here is the for sale paper I talked to the guy and he said its right around 120000miles.
Just thought somebody might be interested:
FOR SALE
1994 FORMULA FIREBIRD
INSIDE NEEDS HEADLINER AND DRIVERS SIDE PW MOTOR
OUTSIDE NEEDS RIGHT FRONT FENDER
MOTOR NEEDS NOTHING!!!!
LT1 MOTOR (SAME AS CORVETTE AND CAMARO)
BBK CERAMIC COATER COMPETITION HEADERS
BBK TWIN 58mm THROTTLE BODY
VENOM 36LBS HR FUEL INJECTORS
K&N COLD AIR INDUCTION
TRICK FLOW ALUMINUM INTAKE ELBOW
LT4 HOT CAM AND BODY
LT4 PORTED AND POLISHED HEADS
CENTERFORCE DUAL FRICTION CLUTCH WITH STEEL FLYWHEEL (1000 HP RATING)
FELPRO GASKETS ALL AROUND
FORGED 10.4:1 ALUMINUM PISTONS
SUMMIT STAGE 2 CONNECTING RODS
EAGLE 355 STROKER CRANKSHAFT
SUMMIT CHROMEMOLY ONE PIECE HEAT TREATED PUSHRODS
MILDON PERFORMANCE OILPAN
HIGH VOLUME OUTPUT OILPUMP
HIGH FLOW WATER PUMP
160% LOW TEMP THERMOSTAT
HURST SHORT THROW SHIFTER 6 SPEED
EDELBROCK POLY-E BUSHINGS FRONT AND REAR
KYB ADJUSTABLE SHOCKS
SERIOUS INQUIRIES ONLY AND NO JOYRIDES
ASK FOR MARC AT (0700-1700) 0170-722-7197
06227-859-147 (1700-2100)
$3800.00
:wink:
