It is currently Mon Aug 24, 2026 12:51 pm
Post new topic Reply to topic  [ 49 posts ]  Go to page 1, 2, 3  Next
 Post subject: my car is up for grab's
PostPosted: Fri Dec 21, 2007 8:41 pm
just looking for a decint offer I will knock some off because I need to give power of atterny to someone because I am leaving. I started the car when they loaded on the truck and it ran fine. sent me a pm or call me 016098673245
 Post subject: Re: my car is up for grab's
PostPosted: Sat Dec 22, 2007 9:04 pm
Chris....
would you part it out or is it whole?
if it's whole be kind and sell it off to the junk yard here outside of Ramstein and that way us locals could scavange it.
jamie
PostPosted: Sat Dec 22, 2007 9:13 pm
I doubt it. I will have to give someone power of attorney for it so I would be willing to knock some of the price for taking care of it.
PostPosted: Sun Dec 23, 2007 12:33 am
damn it with a newborn I can't buy a whole car but I need some stuff off your car, Center Con, washer wiper motor and some other stuff.....
someone buy it for the motor and part the rest out
PLEASE
PostPosted: Sun Dec 23, 2007 7:39 am
I`d just need the motor and wiring for the chevelle but since I put around 4-5g in my suspension and still need to get everything reassembled for the chevelle I am pretty much broke right now. (being 18 going to high school and working at a auto hobby shop)
PostPosted: Sun Dec 23, 2007 7:54 am
Maybe you could state an estimate of how much you'd like to get out of the car, folks could post what they need, that way once the cost is covered, somebody could just get the whole car ... (I'd need the rear interior light cover ;) )
PostPosted: Sun Dec 23, 2007 10:31 pm
I am down for whatever but I NEED to give someone power of atterny for it.
PostPosted: Mon Dec 24, 2007 4:33 am
chris what do you need ($$) out of it to make you happy......
i.e if I took the car and PA, parted out the car and was left with the shell and my parts what $$$ amout would you be looking for in the end?
You looking for a couple (2-3K) of grand for the shell and cost of farmed out parts?
PostPosted: Tue Dec 25, 2007 1:39 pm
2-3 grand would be great I am not trying to make a killing off it.
PostPosted: Tue Dec 25, 2007 6:54 pm
I need:
1.) Aluminium Driveshaft
2.) Battery near mint condition
3.) Lowering springs
4.) Y Pipe from 3.8 V6 with good or bad cat
5.) other suspension parts (sway bar/panhard etc)
Mr_Mike6@gmx.de
PostPosted: Tue Dec 25, 2007 7:05 pm
Some more of the stock WS6 suspension parts might help your V6 ... front sway bar for example (unless you already replaced it with an aftermarket part). I don't think the Y-pipe from the LS1 will fit ...
As for the battery - Mike & Frank's has battery adapters that allow you to use standard European batteries ... the only cost a couple € ... just make sure you get one of the batteries that have double poles, that way you don't have to extend the cables ...
PostPosted: Tue Dec 25, 2007 7:17 pm
Yep, i know with the Y pipe, but if i have luck...somebody have one from a 3.8 V6
Garry, do you know which suspension parts from a V8 are for my 98 Camaro convertible a upgrade? Swaybar? Panhard rod? Driveshaft.. any other?
PostPosted: Tue Dec 25, 2007 7:27 pm
I think the PHR is the same on both ... as is the rear sway bar IIRC ... I think the springs might be worth while swapping out ...
PostPosted: Tue Dec 25, 2007 7:55 pm
i would buy the WS6 Hood.
if not destroyed..lol
PostPosted: Tue Dec 25, 2007 8:32 pm
Well, the rear doesn't have too many good parts anymore :(
Btw, Chris, were the front wheels still OK, and what size?
PostPosted: Tue Dec 25, 2007 8:35 pm
1.) Aluminium driveshaft
2.) front sway bar
PostPosted: Tue Dec 25, 2007 8:40 pm
The hood had a little bit of damage nothing that couldnt get fixed.
PostPosted: Tue Dec 25, 2007 9:33 pm
You'd probably need the fascia, too ...
PostPosted: Wed Dec 26, 2007 8:52 am
Well let me know what happens with your car or how much you would want for the hood and fascia. How hard is the ram air to get off those? Would you even part it from the engine if offered to buy?
