It is currently Mon Aug 24, 2026 12:51 am
 Post subject: 98 windshield washer resivor
PostPosted: Wed Feb 06, 2008 4:21 pm
in good condition without the pump $10
had to use a smaller one to make way for a fanned tranny cooler :)
email at baldur279@hotmail.com
or SMS to 0176-2420-9741
 Post subject: Re: 98 windshield washer resivor
PostPosted: Tue Feb 26, 2008 9:29 pm
sorry I don't need it but you have my attention on teh tranny cooler...what bottle you useing now and were/how is it hooked up? I have a 98 TA and need to mount my B&M cooler. I can't use the usaul spot cause I have teh Fst Toys Ram Air in the way.
PostPosted: Wed Feb 27, 2008 1:51 am
I pulled a smaller washer fluid container out of a golf I believe. It was a wierd shape that just so happened to fit halfway into a hole in the metal bumper kind of where the old fill cap was. The cooler fit directly under the hood latch (It was a derale I got from summit). Unfortunately, it was not large enough to cool the trans (I took the stock cooler out of the loop) and I lost 3rd and 4th gear on the autobahn. I had to sacrifice my SLP ram air for an additional 2 coolers (1=28,000 GVW and 1=12,000 GVW). All 3 in series so I shouldnt have a problem anymore :)
PostPosted: Wed Feb 27, 2008 11:39 pm
WOW....loosing a trans is scary...you got an A4 or M6? if its an A4 PM me I need to ask some more Q's
I know my B&M will do fine its rated at 14,400btu *bigger is better in this case*
I would get rid of the three and get one
