It is currently Mon Aug 24, 2026 4:07 am
 Post subject: Leftovers ...
PostPosted: Tue May 27, 2008 5:56 pm
OK, got some parts left over from my motor upgrades ... all are new unless otherwise stated ...
- Comp Cams High Performance GM LS1 Valve Springs Part# 26918-16; originally (recommended and) bought to go with my TR 224 LSA114 Cam; about twice as strong as the stock springs
- Thunder Racing Pushrods 7.400 .080
- Intake and Exhaust Valve Stem Seals
- GM Crank Seal, Part# 12585673, 2 pcs
- GM LS1 Valve Cover Gasket (98), Part# 12556429, 2 pcs
- GM Front Cover Gasket, Part# 12574294, 2 pcs
- GM Water Pump Gasket, Part# 12588372 (1999+), 2 pcs
- GM Water Pump Gasket, Part# 12559648 (1998)
- 8 AC Delco Spark Plugs, Part# 12571164 / 41-985, used, but good condition (had to get new ones as those would fit my new heads)
- GM Heavy Duty Timing Chain, Part# 12586482
- GM Harmonic Balancer Bolt, Part# 12557840
 Post subject: Re: Leftovers ...
PostPosted: Wed May 28, 2008 10:31 am
Hi Garry,
I could need the valve cover gaskets if they are for the center bolt ones :)
Sending you a pm.
Roozbeh
PostPosted: Wed May 28, 2008 10:49 am
Just checked the web, looks like they are for a 98 motor ... (not sure how come - should have been for my 99/2000 motor)
I'll take a look tonight ...
PostPosted: Thu Jul 17, 2008 7:16 am
*Bump*
Anybody need anything of these? Can bring it to Bitburg this weekend ...
PostPosted: Thu Jul 17, 2008 3:10 pm
Can you MPS? I would be interested in these.
PostPosted: Thu Jul 17, 2008 3:28 pm
No, but I could give them to somebody (e.g. James) ... I take it you only need one each of the gaskets?
PostPosted: Thu Jul 17, 2008 3:36 pm
I only need one of each, but it never hurts to have backups.
Do you need a place to stay on your way to Bitburg?
PostPosted: Tue Sep 30, 2008 5:18 pm
*bump* Bringing it to Bitburg ... if anybody needs anything, let me know ...
