It is currently Mon Oct 26, 2026 2:25 am
 Post subject: 4th gen Adjust Front Lower A-ARMS (Camaro, Firebird&TransAm)
PostPosted: Mon Jan 18, 2010 4:18 pm
Hi,
Used lower A-Arms (used only 2 months) in perfect condition to upgrade your F-Body. Tubular A-Arms are designed to outperform the stock setup whether it’s at the race track or an added improvement to your daily driver; they've been tested and improved to handle both applications. These A-Arms are designed to add front end rigidity, increased strength and to eliminate flex found with stock A-Arms. If your vehicle is exposed to street driving and/or drag racing these upper A-Arms are the perfect set-up for you.
See below link for more information:
http://www.umiperformance.com/catalog/i ... ji8u93ld35
Price: 195,00 Euros (freight costs not included)
Grease-able polyurethane bushings (grease not included)
Thanks
