It is currently Wed Oct 21, 2026 10:46 am
 Post subject: What is your top speed at Nuerburg & Hockenheim?
PostPosted: Sat Nov 17, 2007 6:15 pm
I am just wondering because I have a VERY steep gear with little top end.
PostPosted: Sat Nov 17, 2007 6:16 pm
... which should be fine for Nürburgring ...
PostPosted: Sat Nov 17, 2007 6:50 pm
Nuerburgring: About 136 mph (before Schwedenkreuz).
Hockenheim: About 130 mph (before Spitzkehre).
PostPosted: Sun Nov 18, 2007 12:08 am
Hmmmm.... I am not even sure I can hit that :twisted:
PostPosted: Sun Nov 18, 2007 7:36 am
Have you tried Fbodyeurope's speed in gear calculator?
clickhere
PostPosted: Sun Nov 18, 2007 10:58 am
Hmmm. It says I am good to go. I'll definitely give it a go as soon as I get this beast to pass inspection.
Thanks for the info.
PostPosted: Wed Nov 21, 2007 6:13 pm
So what gears are you running in the rearend?
PostPosted: Wed Nov 21, 2007 6:48 pm
Aaaaah............itty bitty 4.56's :twisted:
PostPosted: Wed Nov 21, 2007 6:53 pm
That rear gear will probably get pretty hot on the Nordschleife when driven at speed there.
PostPosted: Wed Nov 21, 2007 6:56 pm
I am sure it will, but I guess I just had not thought too much about it. I will definitely going to have to try though. I cannot pass up on the oppurtunity while I am here and I do not know of anybody that does gears (that will be here past FEB).
