It is currently Wed Sep 09, 2026 6:11 pm
 Post subject: Quick Update
PostPosted: Sat Aug 23, 2008 4:04 am
New PB with the N2O: 10.77 @ 132, 60ft left a lot to be desired at 1.8.
Best all motor is 11.1 @ 119 and my PB all motor MPH is 120.
Good times at the tracks here in the US of A but just not the same as running at Racewars and Speed Days. Wish I was back there.
Full Bassani Exhaust
AEM Meth Injection
 Post subject: Re: Quick Update
PostPosted: Sat Aug 23, 2008 10:47 am
These are impressive times!
PostPosted: Tue Aug 26, 2008 2:45 am
Thats impressive, that's with the new build as well isn't it?
02 Ford Mustang GT Vert
PostPosted: Fri Sep 26, 2008 5:40 pm
New best....got it to hook.
1.51 sixty
10.16 @ 134.5
http://www.youtube.com/watch?v=uSkYyw4_pGk
AEM Meth Injection
PostPosted: Sat Sep 27, 2008 8:51 am
That was impressive.
PostPosted: Sat Sep 27, 2008 9:03 am
Not far to go for SG index ...
PostPosted: Sat Sep 27, 2008 6:38 pm
We are thinking that if we change out the fuel jet and fatten her up we can get it in the 9's safely.
It was running a bit lean that night.
AEM Meth Injection
PostPosted: Sat Sep 27, 2008 7:02 pm
Lean & N2O don't mix well ... but I guess I don't need to tell you that ;)
PostPosted: Sat Sep 27, 2008 7:22 pm
The upside is that with tweaking the tune and adding more fuel we will get it moving faster.
The nitrous really just allows you to dump more fuel into the engine which is the combustion agent.
AEM Meth Injection
PostPosted: Sat Sep 27, 2008 7:30 pm
Good luck aiming for the 9 ...
PostPosted: Sun Sep 28, 2008 3:01 am
I recognize that car, are you not loading your stall? It doesn't sound like it, loooks good man, Oh, and I see you have the tape on there, I used to do that, now I just spray WD 40 on the fenders, exactely where you have your tape now, then when you get done you just spray the WD off and all the rubber washes right off:)
Picked that one up over the years, I even do it for the autocross now, of course some of you guys remember my playtime's:)
PostPosted: Sun Sep 28, 2008 6:22 am
My best times have come without revving it up.
AEM Meth Injection
PostPosted: Sun Sep 28, 2008 8:04 am
... a generous layer of Zaino might also to the trick ...
