It is currently Mon Aug 24, 2026 8:23 pm
 Post subject: One last tech. question
PostPosted: Wed May 08, 2002 8:17 pm
Now I do not have a convertible, but I do know someone who does. And as your rules state below:
Roll bar required in any vehicle running between 6.40 and 7.49 (1/8th) or 10.0 and 11.99 (1/4) seconds; convertibles between 7.0 and 8.59 (1/8th) or 11.0 and 13.99 (1/4) seconds; roll cage required in any vehicle faster than 6.39 (1/8th) or 9.99 (1/4) ET; convertibles faster than 6.99 / 10.99. Roll bar / cage structures must meet minimum NHRA standards as found in 1994 NHRA Rulebook.
I have been told you are following NHRA rules and if my memory serves me correctly the NHRA rules state that a roll bar is required in a convertible that runs under 12.99 in the 1/4 mile. Do your rules have a miss print? I may be wrong, but if your rules are correct then almost every convertible LS1 Camaro totally stock from the factory could not run in your events unless they had a roll bar installed? This just does not make sense to me. Please advise!
PostPosted: Thu May 09, 2002 5:25 am
Lets see if the rule can be amended.
i.e. top must be up and helmet worn.
IHRA rules are a little different in this area.
