It is currently Fri May 01, 2026 2:59 pm
 Post subject: 22 july ( auto cross event)
PostPosted: Wed Jul 11, 2001 6:18 pm
It also known as Cone punting.
where: SEMBACH AIR FIELD
when: 22 july 2001 0900 hours. Come at 0800 to walkthe track and dump all the junk out out of the car.
how much: 50 DM
who is sponsoring : PCA-GR
how many laps: 3 practice and 3 qualifying laps.
PostPosted: Thu Jul 12, 2001 7:37 am
If your scared of having some good fun and a good laugh or two just say so. I can understand the fear of being intimidated by a Porsche 924 or 944.
PostPosted: Thu Jul 12, 2001 4:51 pm
I will be in Nurnburg. Sounds like fun. I took your advice with the front end with the Neg camber and slight toe. I did not remember the numbers you said but It really helps in the twisteeez. Thanks.
PostPosted: Thu Jul 12, 2001 4:59 pm
Are we able to adjust the stock settings?? :confused:
PostPosted: Thu Jul 12, 2001 5:00 pm
PostPosted: Thu Jul 12, 2001 6:24 pm
Jack
Yes you can
A good start is -.5 degrees camber and 4.5 degrees of caster
PostPosted: Thu Jul 12, 2001 7:21 pm
Ok, HOW do we do make adjustments??
PostPosted: Thu Jul 12, 2001 9:44 pm
I took mine to a tuning wheel and tire shop. And it stays more neutral and flatter in the twistees. You must still must be careful with the corner bump steer.
PostPosted: Thu Jul 19, 2001 7:57 am
I know a lot of you folks are going to the Nurnburg show, but is there any body besides my self that is going autocrossing on the 22nd .
PostPosted: Thu Jul 19, 2001 8:02 am
I am interested, It is a bad weekend for me. Thanks I will try to be there next time.
PostPosted: Sun Jul 22, 2001 5:31 am
I am on my way this morning to Sembach . If you didn't go to Nurnberg then why don't you stop over at Sembach and check out the action.
 Post subject: maybe
PostPosted: Sun Jul 22, 2001 12:38 pm
If the cars up by then I'll be there. I know I'll be the slowest car out there in the corners due to no suspension mods. But hey hopefully there's a few straight aways. I'll let you know In a future post the status on my car.
