| BITBURG BX Car Show and Soundoff http://forum.fbodyeurope.org/phpBB3/viewtopic.php?f=2&t=5815 |
Page 1 of 1 |
| Author: | slickmetal.com [ Sat Jun 18, 2005 6:53 pm ] |
| Post subject: | BITBURG BX Car Show and Soundoff |
had a car show and DB drag at Bitburg BX today...I got 2nd place in SPL (Sound Pressure Level)...138.67 dBs Best of all: Entry=FREE 2nd Place for dB = 65$ AAFES Gift Card 1st place hit 139.48 I got with .3 or .4 of the winner at one point, then they changed there fuses and started hitting louder Some Mighty Mustangs showed up...wasnt huge due to ORI kicking offf this weekend. |
| Author: | Jazzy91 [ Mon Jun 20, 2005 3:02 pm ] |
| Post subject: | |
Glad you did good. |
| Author: | Jazzy91 [ Mon Jun 20, 2005 3:03 pm ] |
| Post subject: | |
Glad you placed.
| Author: | Chewy [ Mon Jun 20, 2005 3:04 pm ] |
| Post subject: | |
Good job man. what type of equip are you running? |
| Author: | slickmetal.com [ Mon Jun 20, 2005 3:47 pm ] |
| Post subject: | |
Jaz, I was a bit ticked off when I first started..plus I had to go first Sweep - was told 60 hz was loudest 1st Run amps at about 80% - tuned to 60hz - 50Hz Sub LPF was ON in 2nd Run amps about 90% - tuned to 60hz - Sub LPF set to THRU I am an idiot. Not to do a sweep AFTER an adjustment...at this point I was in 3rd (last place) because Juans (Sunfire) car hit 135-136 with 2x 10's with the gains down and the Golf Hit 139.21 w/ a W7 So I asked to go again with a sweep....and the Hz did change...I can remember but I think it was in the mid 40s...I hit 138.21....then I turned the sub volume to 6 and bass to like 5 or 6, blocked off the trunk as much as possible with my Vert bracket bag and I hit 138.67 - then it was too hot...and I stopped...and my ears were goin' nuts. I can easily hit 140s if I was able to use the sound foam on my top....everyone was blowing fuses but me....the Golf was getting nervous, because at one point I was very close to topping....she used an 80 amp fuse, and got 139.48...to win... Chewy: the list Clarion 8 Series Head Unit CD/MP3 Metra Install Kit w/ harness Audio System PMR-4 Equalizer 2x JL Audio 12W6V2 Subs 1x Audio System 200 Serie Component Set (Mids,Tweets & X-Over) 1x Focal 160 a Component Set (Mids,Tweets & X-over) 2x Audio System F2450 Twister Amps 750w RMS ea. 1x Audio System F4560 Twister Amp 880w RMS Tsunami Power Pumper 3 Farad Capacitor Tsunami Electronically Fused Distro Block w/ Digital Head Unit Tsunami A/V Console Tsunami Sub Wires Tsunami 200 AMP Fuse Raptor Inline Fuse Holder Raptor 0/1 Guage Power/Ground Wires EFX/Monster Interconnects Optima Yellow Top Battery Tsunami Yellow Topper Unit Custom Fiberglass Sub-enclosure by JZ Customs (Sealed) Medion GPS Navigation w/ MP3 Rear Trunk Amp Rack |
| Author: | slickmetal.com [ Mon Jun 20, 2005 7:26 pm ] |
| Post subject: | |
14 pics.... http://www.teamurbanvelocity.org/bxshow/ |
