It is currently Sat Oct 24, 2026 2:53 am
 Post subject: Software update ...
PostPosted: Sat Feb 01, 2003 8:41 am
Spent some time this morning updating the message board software ... and after that, the IM client (which took quite a while) - everybody should get a window asking to follow a link and check the settings - if you want to use the IM, just do so and confirm the settings (they should be the same as before, just that they weren't modifieable) ... or change them to your liking ... sorry for the inconvenience ...
P.S. - for the moment, the IM-Window doesn't seem to open automatically - looking into that tonight ...
PostPosted: Mon Feb 03, 2003 8:13 am
OK, fixed the popup-problem, at least the window will popup again ... only drawback is you can't disable it via the prefs ...
