It is currently Sat Oct 24, 2026 1:58 am
 Post subject: Image Gallery
PostPosted: Fri Jun 11, 2004 9:52 pm
OK, set up an image gallery for general use ... take a look ...
http://www.fbodyeurope.org/Gallery
PostPosted: Sat Jun 12, 2004 6:34 am
OK, maybe some quick hints on using the gallery ... should be pretty straight forward ...
First of all, if you want to upload any images or videos, you will have to register ... it has no connection to either the website or the forum ...
Once you're logged in, you can create an album with the "new album" link. I have added some basic top level albums, like FBE Meetings, to get the whole thing organized a bit ... (if you have suggestions for more top level albums, just let me know)
Once you have decided what and where you want to post, go into that album and create a new sub album (from the drop-down menu). Please add some information on the properties entry of the album, and define a fitting title ...
To upload, the gallery has several ways, the nicest is the Java applets which will let you add pictures by dragging them from your hard disk into the window ... once you're done, just start the upload and sit back ;)
So much for now, let me know if you have any problems with it ...
