It is currently Sat Oct 17, 2026 6:55 pm
 Post subject: Roy needs to buy a Focus
PostPosted: Sun Jan 20, 2008 9:58 am
This I have to get more info on!
Engine:
Harvey Gibbs Build 2000 c.c. DOHC 4 cylinder 16 V :new Cosworth cast Iron Block Cosworth 7.2:1 pistons : Group'A' Big-end bolts : Long Studded : High pressure oil pump : 4x4 big Wing Sump, Gas flowed & ported Head by Nick Waples : Uprated valve springs : Bronze valve guides : WRC 4 Layer Head gasket Harvey Gibbs profile cams : 8 x 803 (dark green) injectors : 3 Bar Mapsensor Weber-Marelli Fuel Injection with Super P8 Pectel Management : :Swirl Pot: 3 Fuelpumps with Catchtank: RS500-Throttle body : Custom Inlet Manifold : Ford Motorsport Leads : distributorless Ingnition System : WRC Siamese (side by side) 8-Injector Manifold : AGP 071 Plugs
GT030 Turbo-charger : External Tial Wastegate : pro Alloy Turbo Pre-Radiator : SPAL Cooling Fans : Pectel 12 Stage Boost Controll: K+N Induction kit : Pro Alloy Inercooler Big Version : pro Alloy Large Capacity Radiator : Pro Alloy High Pressure Header Tank : Samco Hoses : Pro Alloy Breather System : Tubular exhaust manifold: Mongoose Stainless Steel Exhaust :Specially programmed Ahmed Bayoo ISS (Inercooler Spray System) : Oil-Cooler : Chip live mapped on engine dyno
MAX Power: 529 BHP @ 354.9 lb.ftC + 26 PSI @ 7510 rpm
MAX Tourqe: 379 lb.ft @ 7010 rpm 527,9 BHP
Transmission:
4WD Straight Cut Reyland Super Strong Gearbox with Uprated Mainshaft an 1st Gear , Hydraulic Clutch Conversion : AP Racing 6 Paddle Sinter Clutch : Rear: 2WD 7,5” Diff with 2WD Propshafts Quaife ATB Diff 3,9 CPW,
Front: Quaiffe Thickwall Case with Quaiffe ATB Diff,steel strength Plate XR4i uprated front Propshafts CAE Race Quick Shift System
Brakes:
Front: AP Racing 380mm discs/6pot calipers
Rear: AP Racing 330mm discs/4pot calipers
Hydraukic Handbrake with AP adjustable rear Brake Balancing
Suspension:
H&R Unibal adjustable coilovers front and rear
Adjustable TCA´s, Aloy Exentric Top Mounts
Zoo Motorsport full adjustable Rear Beam Strapped Version
Wheels:
Compomotive CTX 8x18 ET 20
Front : Federal RS 595 Semislick 225-40-18
Rear : Federal RS 595 Semislick 245-35-18
Interieur:
Cobra Evolution Seats
Stack Dash
Defi Gauges for Exhaust Temp, Fuelpress, Boost
Pectel Monitor System
Sparco 35mm Steering Wheel with Quick release
Wolf Alloy Pedals
Carbon Tunel Liner
Carbon Interieur
80LTr ATL Race fuel Tank
Wichers Rollcage
Heating System from Mini
Exterieur:
Smoked rear lights and Brake Light
RHD rearlight
Black Indicators
WRC Rear Wing
Bonrath one wiper System
Sierra 4x4 Bonnet Vents
Carbon Front Splitter
Carbon Foglight Surrounds
Self made Carbon Difusor
http://forums.focaljet.com/team-pit-sto ... rmany.html
 Post subject: Re: Roy needs to buy a Focus
PostPosted: Sun Jan 20, 2008 3:48 pm
A cossie engine and AWD makes for a proper focus.
PostPosted: Sun Jan 20, 2008 9:02 pm
Yes I though it was funny they said they used a Sierra drivetrain on it. It does look well put together. Check their site there are some goodies there.
PostPosted: Mon Jan 21, 2008 7:05 am
I could get you a couple SHO motors for the Focus if your Interested? you could have a FoSHO when completed.
PostPosted: Mon Jan 21, 2008 9:53 am
It has been done many times. In FWD as a matter of fact. The is a SHO in Baumholder but not the Yamaha V8. Focos has been named the best Cossie conversion on the world and will be at the big car shows in the UK this year.
PostPosted: Tue Jan 22, 2008 9:49 am
James this is old news, they have been building focus cossies for many years allready :D
the gearbox used to be the biggest problem when shooting for (very) high power 4x4 in a focus, they seemed to have fixed it now with some expensive "he said poop"
PostPosted: Tue Jan 22, 2008 10:13 am
yeah the stock AWD gearbox has got me worried alittle .
PostPosted: Tue Jan 22, 2008 5:58 pm
I know thye have been doing this for many years now, even before the RS even came out. From what I have been told though it is the best Cossie conversion done on a Focus.
