 Post subject: Differential whine?
PostPosted: Tue Apr 23, 2002 10:07 am
Hi,
has anybody else experienced this:
Between about 70 km/h and 120 km/h (43 mph and 75 mph) I get a high pitched whine from the back of the car, i guess from the differential. I get this always (in and out of gear) except when I'm accelerating. Dealer says it's normal... what do you think?
PostPosted: Tue Apr 23, 2002 11:52 am
Ben I had basically the same thing . In the end I prevailed and Herr Kopps had the gears replaced.
PostPosted: Tue Apr 23, 2002 3:40 pm
Ah, thanks Roy, good to know. The next time they tell me it's "normal" I'll ask them why they fixed it on somebody else's ( = your) Camaro. :)
BTW, it seems that Herr Kops is never there when you need him. I called today because of some "special tools" they wanted to order because of problems with my A/C and they told me that Kops is not there this week... :(
PostPosted: Sun May 26, 2002 8:31 pm
I have the same thing now.. but it is due to my gear replacement.... but I also had it befor and it turned out to be a side bearing going bad.
PostPosted: Thu Sep 12, 2002 6:54 am
Did you check fluid levels in the diff and check for little metallicky type flakes etc...?
