It is currently Mon Aug 24, 2026 5:29 am
 Post subject: old cheap plastic + cold + stress = bad...
PostPosted: Sat Jan 28, 2006 2:25 pm
Engaging the turning signals felt pretty soft suddenly,
and then you couldn´t engage or stop them at all anymore...
After puzzling everything back together from the floor,
i found the problem (lever removed...):
Let me guess... i have to remove the steering wheel to get access to that part? Even if glueing (with lot´s of fiber glass) would be possible... that cover is still in the way.... :x
I still can use the turning signals but it get´s pretty annoying.
PS: YES, i know, that car is dirty. ;)
PostPosted: Sat Jan 28, 2006 2:40 pm
Ouch!
PostPosted: Sat Jan 28, 2006 3:45 pm
Just fix it I am sure there is an aftermarket company that sells that like at Advance Auto Parts Online from Wagner that you can get a new one. KFG will not fix that.
