It is currently Wed Oct 14, 2026 1:25 pm
 Post subject: 996tt brake setup opinions?
PostPosted: Thu Sep 13, 2007 9:26 am
This goes especially to Roy: :wink:
Any opinions to the Prostop 996tt brake setup as offered on frrax.com?
How does it compare to your Movit system, is it superior or inferior?
PostPosted: Thu Sep 13, 2007 2:15 pm
Basically the same setup (Brembo).
PostPosted: Thu Sep 13, 2007 6:59 pm
Its basically the same .
It uses Porsche calipers and rotors in the basic kit anf two pice rotors in the upgrade kit.
PostPosted: Fri Sep 14, 2007 9:34 am
What kind/size of wheel spacers do you use, Roy to fit the brakes?
PostPosted: Fri Sep 14, 2007 3:04 pm
On the front I use MOVIT specific hub centric wheel spacers. I don't know the thickness right off hand though.
PostPosted: Sun Sep 16, 2007 9:54 am
The 996tt kit requires a 25mm spacer PLUS an additional spacer before the rotor mounts to the hub.
PostPosted: Sun Sep 16, 2007 10:49 am
WWTS?
(What would/will TÜV say?) :lol:
PostPosted: Sun Sep 16, 2007 12:27 pm
Well the Movit Kits got the TUEV ok
PostPosted: Sun Sep 16, 2007 2:08 pm
The Movit is more expensive with similar hardware. TUeV for the other kit could be done I guess.
The spacers thing is what makes me think. I don't like them... generally.
Roy, what is the weight of your Movit stuff, i.e. calipers, pads, rotos compared to stock? Is yours much heavier?
PostPosted: Sun Sep 16, 2007 2:45 pm
Ben All I can tell you is that it is heavier.
PostPosted: Tue Oct 02, 2007 11:02 am
With the 996tt setup and those spacer, you need new wheel studs.
Now, let's assume we take a STOPTECH kit which would need as the only spacer a 10mm one (I'm not 100% sure but that doesn't matter right now). Would I also need new wheel studs with the 10mm spacer?
I also found the H&R DRM TRAK+ spacer which looks like it has built-in new wheel studs...?
PostPosted: Tue Oct 02, 2007 7:09 pm
Yes new longer studs are mandatory . Also the Stoptech Kit is a pretty good kit .
PostPosted: Tue Oct 02, 2007 8:55 pm
OK. :)
Roy, can you take a look at this:
http://www.h-r.com/index.php?inhalt=pro ... sprache=de
The DRM system should be for our cars. It looks like that spacer is mounted on the "old" wheel studs and has built-in new studs. Can this work? I mean, aren't the old studs subject to forces that may lead to their failure with this system?
I don't quite understand that...
PostPosted: Wed Oct 03, 2007 5:23 am
As long as the spacer is hub centric it should be fine. BUt Ireally wouldn't want to be putting the stresses of Hockenheim through them.
