It is currently Tue Sep 29, 2026 8:42 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
PostPosted: Sun Mar 28, 2004 12:07 pm
Damn. I'll keep that in mind! Mine probably whines too but I can't hear it.:D I'm gonna put some redline in there when I get back as a temporary band aid. I think its safe to say though Jack you've got more high speed blasts than I do. Mine stay outta commission more than anything else.
Looks like I'll be putting some $$ into the secret squirrel fund for real now....just in case.
PostPosted: Sun Mar 28, 2004 1:03 pm
Yeah, I think I'll be ordering mine around the 15th of May John, so if you want to go in with me, that'll be the time! :)
PostPosted: Sun Mar 28, 2004 1:34 pm
JAck I don't have theactual price because it was part of the package. But it was an additional 200 bones I believe above the normal LSD.
If you get one don't be shocked by the amount of noise they make when turning real tight.
PostPosted: Sun Mar 28, 2004 1:46 pm
I can handle it if you can. You make a lot more tight turns than me. :)
PostPosted: Sun Mar 28, 2004 7:04 pm
whinning is a bad bearing or race also if you broke your drive shaft something was out of wack IE binding on your ring and pinion did you have any vibration?
PostPosted: Sun Mar 28, 2004 7:06 pm
None that I noticed, but the drivetrain would probably tell you otherwise.
PostPosted: Sun Mar 28, 2004 7:17 pm
I dump da clutch @ 5500 with 10 in slicks and a stock driveshaft for 2 years got a slight vibration now @130MPH. However I just ordered a 3 1/2 in custom drive shaft with forged yokes setup for 700 hapees with slicks.
PostPosted: Sun Mar 28, 2004 7:34 pm
D@mn Bruce, are you heading for a 4-digit HP rating??? :lol:
PostPosted: Sun Mar 28, 2004 7:41 pm
I was thinking about going with the Denny's driveshaft. It is "virtually unbreakable", and if you ever twist it, or break the welds, they will replace it for free. Can't argue with a lifetime warranty! :D
PostPosted: Mon Mar 29, 2004 6:33 am
I think that all your bearings are shot. The side bearings because it looks like the diff isn't centered and would explain some of the markings on the diff, looks like the diff shifted from side to side due to...The pinion bearing because the pinion gear hit the diff. The nut could have come loose as well. Was the nut ever removed or was there markings on it indicating that? How much side to side movement was there (diff)?
All I can say is sorry. :(
PostPosted: Mon Mar 29, 2004 7:37 am
Trying to run 650 streetable hapees this year maybe 700 if I get brave.
PostPosted: Mon Mar 29, 2004 8:04 am
To my knowledge, nothing from the yoke back was ever touched! That makes sense about the diff, but I tried moving it, and there didn't seem to be any play at all.
