It is currently Tue Sep 29, 2026 7:01 am
 Post subject: 3rdgen Ram Air
PostPosted: Mon Jun 04, 2001 5:38 pm
...Once again. This one is a bit more functional than the last :). I like that its not seen when the airbox is on. Air is grabbed from behind the fog lights, which I may or may not remove. I like the lights, so I might replace them with smaller ones for increased forced air...
91 black Z28
ON ITS WAY TO USA!!
PostPosted: Tue Jun 05, 2001 5:25 am
Greg that is looking real sharp. Did you custom make that?
PostPosted: Tue Jun 05, 2001 11:32 am
Yeah, just some ducting from the local hardware store (Home Depot in the states would have been cheaper). We bought the wrong stuff a few times untill we came up with what you see. Very functional, and a noticable throttle responce increace.
91 black Z28
ON ITS WAY TO USA!!
PostPosted: Tue Jun 05, 2001 12:36 pm
That does look good, and is a better design than what I had with my under the fender scoop. All I did was suck in debris, which liked to stick to the oily K&N.
And if you decide you dont want to draw air like that anymore, just reroute the ducting to the front discs for brake cooling... bonus
