It is currently Tue Sep 29, 2026 7:27 am
 Post subject: german engineering at its best *cough* or: my flux capacitor
PostPosted: Thu Apr 08, 2004 8:17 pm
In the last few month i had a strange problem with my car.
If i fired it up cold it was running just fine.
But sometimes when i started the engine warm it was running like crap, i even could smell fuel. I changed coils (the accel coils i had are notorious for failing under heat), wires, plugs - no change.
2 weeks ago i found out that the connector on the coolant temp sensor broke off and was loose which caused the problem (the PCM assumed the engine was cold and dumped in fuel, it was running pig rich, i guess).
First, I made some temporary solutions, of which none lasted long:
pay attention to the hose clamp, the copper wire and the duct tape :lol:
Then I finally got a replacement sensor and tried about 8h to get the old one out, using wrenches, pliers, a heat gun, just brute force
and other sophisticated crap. After that, it looked like this:
And as you can see it didn´t come out, but decided to desintegrate... :x
But i was not keen on pulling the upper intake, the injectors and the lower intake just to get that stupid sensor out.
So I drove to OBI and bought some stuff in the "toilet section" :lol: And then I finished the...
...FLUX CAPACITOR! (anybody remembers "Back To The Future"?)
It bolts right up into the former throttle body heater hoses (which i bypassed anyway) and carries a coolant sensor out of my berettas. (thanks to teflon tape its even leakproof :lol:).
Tomorrow I´ll try to travel back into the fifties, i think.
Hopefully I can hit 88mph somewhere.
Next mods for the car include a fountain and a toilet flush... ;)
PostPosted: Thu Apr 08, 2004 8:20 pm
:lol: cool job! Guess you should write that up for the tech section of the site ... not too much to do ;)
PostPosted: Thu Apr 08, 2004 8:47 pm
Cool. Not bad at all!
1.21 gigawatts!
PostPosted: Thu Apr 08, 2004 9:13 pm
Hammerhart ;) :D
That means: very good job, don´t believe it ;) :D
http://www.martinerne.de
PostPosted: Fri Apr 09, 2004 4:19 pm
I like what you did! 8)
PostPosted: Sat Apr 10, 2004 10:34 am
Chris...
whatever you smoked or drank while doing this.
I want some too !!!
Marvelous.
BTW.
You up for some meeting action. I wanna hit Berlin next week probably, so i´ll be passing you by.
CYA!
Dino
Got boost?
PostPosted: Mon Apr 12, 2004 2:26 am
thats cool man
